Lightning 275P MTS
SKU# LMTS-275-PULSE
- Unit Weight: 97 lb
- Unit Dimensions: 11.5 in × 26 in × 25 in
The Lightning 275P MTS is a professional multi-process welder built to tackle the variety of work that comes through a busy shop. Combining 275A MIG, 275A AC/DC Pulse TIG and 220A DC Stick capability, it brings serious power and versatility to fabrication, repair and production work. New Synergic Single Pulse MIG helps control heat on sensitive materials, reduce spatter and increase travel speed—giving you another way to handle demanding jobs with confidence.
From short-circuit MIG to spray arc and pulsed spray, the Lightning 275P MTS covers a wide range of applications. Dedicated aluminum, stainless steel, gas-shielded and gasless flux-cored settings simplify setup, while push-pull gun capability expands its aluminum welding versatility. AC/DC Pulse TIG adds precise control, with an updated HV start system for more efficient arc starts. Stick mode handles a broad range of electrodes, including E6010.
PowerSET gets you welding faster by suggesting starting settings from basic information entered in MIG, TIG or Stick mode. Each process displays all settings on one clear page, with no hidden menus or popups. You can also name, save and lock up to 30 custom programs for repeat jobs.
Built to keep working, the unit delivers 60% duty cycle at maximum rated output in each process, plus 100% duty cycle at 200A in MIG and TIG or 175A in Stick. Dual-voltage operation lets you take it to jobsites with 120V power when needed, with reduced output. Whether you’re welding thin material or tackling heavier fabrication, the Lightning 275P MTS puts the tools for the job in one machine.
- Fully Synergic Pulse MIG
- AC and DC Pulse TIG
- PowerSET mode for easy setup of parameters.
- Dual Voltage Operation allows maximum go-anywhere performance
- MIG, AC/DC Pulse TIG and Stick operation handles almost any common welding chore
- Cart and cooler for TIG available as an option and works with rear outlet
- Spool gun and push-pull gun capable (Guns are optional)
- Run-in features improves arc starting in MIG mode
- 5.1" LCD HD 720 Screen for easy view of parameters
- 4 Roller drive system for smooth feeding of wire on longer guns and push-pull guns
- 12" or 8" roll capacity (10-12 lb. or 30-44lb.) provide economical choices of wire selection.
- Save up to 30 programs
- Surge Watts 13,500
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 43 A
240V 1 Phase 50/60Hz: 53 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 34 A
240V 1 Phase 50/60Hz: 41 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720
| Memory | 30 Programs
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 150A/21.5V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 120A/20V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 150 Amps
| MIG Hot Start | Adjustable
| Up-Slope Time | 0-1 Seconds
2T SP
4T SP
| MIG Pulse | Single
| MIG Pulse Pinch Effect | No
| Spool Sizes | 8”
12”
V-Groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Arc Trim (Pulse)
Run-In
Spot
Stitch
| Wire Feed Speed | 120V: 425 IPM 240V: 600 IPM
| Torch/Gun | North 36 Series 10 Ft.
| Important MIG Specification Notes | This unit is equipped with a heavy duty 36 series MIG gun designed for Spray arc welding and using larger .045" and .062" wires. If welding below 230A, purchase a 24 Series gun. If using .035" or smaller wire, also purchase a blue .023"-.035" liner for the 24 series gun or the 36 series gun
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 150A/16V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 275A/21V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 15 to 275 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.6 to 16 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 275 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 16 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 15 to 275 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.6 to 19 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 275 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 19 Volts
Lift Start With Remote
| Start Amp Range AC | 15-(150)275A
| Start Amp Range DC | 10-(150)275A
| End Amp Range AC | 15-(150)275A
| End Amp Range DC | 10-(150)275A
| Pre-Flow Time | 0-5 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Soft Square
Triangular
| Pulse Amperage | 3-95% of Welding Amperage
| AC Frequency | 20-250 Hz
| AC Wave Forms | Square
Soft Square
Triangular
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 120A/24.8V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 90A/23.6V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 220A/28.8V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 120 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24.8 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 220 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28.8 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 7/16""
.015" to 5/16"
.015" to 5/16"
.025"- 5/16"
- 36 Series MIG Gun 3m 10 ft.
- Everlast 18 Series Water-Cooled Amp Control TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru)
- 240V to 120V Pigtail Adapter
- Starter Consumable TIG Kit
- 6.5 Ft. Power Cable with NEMA 6-50 PowerPlug
