Lightning 275P MTS with 301 Cart and W401 Cooler Bundle Package
SKU# LMTS-275-PULSE-301-WC401
- Unit Weight: 97 lb
- Unit Dimensions: 11.5 in × 26 in × 25 in
The Lightning 275P MTS Cart and Cooler Package includes everything that is in the Lightning 275P package plus the PowerCart 301. This bundle package allows the user to use all the functions and accessories that come with the machine, including the water-cooled TIG torch.
- Includes cart and cooler
- Cooler plugs into rear of machine for power.
- Fully Synergic Pulse MIG
- AC and DC Pulse TIG
- PowerSET mode for easy setup of parameters.
- Dual Voltage Operation allows maximum go-anywhere performance
- MIG,TIG and Stick operation handles almost any common welding chore
- Spool Gun Capable (spool gun optional)
- Run-in features improves arc starting in MIG mode
- Push Pull Gun Capable (Push-Pull gun optional)
- 5.1" LCD HD 720 Screen for easy view of parameters
- 4 Roller drive system for smooth feeding of wire on longer guns and push-pull guns
- 12" or 8" roll capacity (10-12 lb. or 30-44lb.) provide economical choices of wire selection.
- Surge Watts 13,500
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 43 A
240V 1 Phase 50/60Hz: 53 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 34 A
240V 1 Phase 50/60Hz: 41 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720
| Memory | 30 Programs
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 150A/21.5V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 120A/20V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 150 Amps
| MIG Hot Start | Adjustable
| Up-Slope Time | 0-1 Seconds
2T SP
4T SP
| MIG Pulse | Single
| MIG Pulse Pinch Effect | No
| Spool Sizes | 8”
12”
V-Groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Arc Trim (Pulse)
Run-In
Spot
Stitch
| Wire Feed Speed | 120V: 425 IPM 240V: 600 IPM
| Torch/Gun | North 36 Series 10 Ft.
| Important MIG Specification Notes | This unit is equipped with a heavy duty 36 series MIG gun designed for Spray arc welding and using larger .045" and .062" wires. If welding below 230A, purchase a 24 Series gun. If using .035" or smaller wire, also purchase a blue .023"-.035" liner for the 24 series gun or the 36 series gun
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 150A/16V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 275A/21V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 15 to 275 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.6 to 16 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 275 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 16 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 15 to 275 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.6 to 19 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 275 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 19 Volts
Lift Start With Remote
| Start Amp Range AC | 15-(150)275A
| Start Amp Range DC | 10-(150)275A
| End Amp Range AC | 15-(150)275A
| End Amp Range DC | 10-(150)275A
| Pre-Flow Time | 0-5 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Soft Square
Triangular
| Pulse Amperage | 3-95% of Welding Amperage
| AC Frequency | 20-250 Hz
| AC Wave Forms | Square
Soft Square
Triangular
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 120A/24.8V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 90A/23.6V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 220A/28.8V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 120 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24.8 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 220 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28.8 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 7/16""
.015" to 5/16"
.015" to 5/16"
.025"- 5/16"
- 36 Series MIG Gun 3m 10 ft.
- Everlast 18 Series Water-Cooled Amp Control TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru)
- PowerCool W401 (240V)
- PowerCart 301 HD Welding Cart with Single Cylinder Capacity
- 240V to 120V Pigtail Adapter
- Starter Consumable TIG Kit
- 6.5 Ft. Power Cable with NEMA 6-50 PowerPlug
