Power i-TIG 200T Front View
Power i-TIG 200T side view
Power i-TIG 200T
Power i-TIG accessory package
Power i-TIG 200T
SKU# PIT-200T-DV
Power i-TIG 200T
Digital DC
$849.00
$620.00
Save - $229.00
Power i-TIG 200T
Digital DC
SKU# PIT-200T-DV
  • Unit Weight: 25 lb
  • Shipping Weight: 30 lb
  • Unit Dimensions: 7 in × 15 in × 11 in
Power i-TIG 200T
The Power i-TIG 200T is a compact digital DC Pulse TIG/DC Stick welder designed for precision welding on stainless steel, mild steel, and other weldable steel materials.
Its stable, low-amperage arc starting capability gives the operator greater control when working with thin and delicate materials, making it easier to initiate a smooth, controlled arc without introducing excessive heat. Combined with adjustable pulse capability, the Power i-TIG 200T provides the control needed for applications where weld appearance, heat management, and precision are important.
The Power i-TIG 200T is particularly well suited for gunsmithing, sanitary welding, fabrication, repair, and other precision TIG applications.
Its small, lightweight design also makes it an excellent choice for portable field work, including production-line maintenance, plant maintenance, and shutdown work, where a capable TIG welder needs to be easily transported from one job to the next. The dual voltage 120/240V input allows it to be plugged in and used on most jobsites whether doing restaurant fabrication work or building handrails on-site.
The stick welding function works well with E7018, E7014, E309L, and other specialty rods. Can be used with E6011.
  2. 7000 Surge Watts
  2. E6011 use is permissible but may be brand sensitive
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 28.6 A
240V 1 Phase 50/60Hz: 27.5 A
120V 1 Phase 50/60Hz: 18 A
240V 1 Phase 50/60Hz: 17 A
9 Programs
120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 125A/15V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/14V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/13.2V Rated Output
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 200A/18V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/16.4V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/15.2V Rated Output
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 2 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 15 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 2 to 200 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 18 Volts
70V
TIG Start Type
Lift Start With Remote
HF Start with Point Gap Start
Start Amp Range DC
2-200A
End Amp Range DC
2-200A
0-25 Seconds
0-25 Seconds
0-25 Seconds
0-25 Seconds
TIG Pulse
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
5-99%
Pulse Amperage
5-95% of Welding Amperage
.005" to 5/16"
.005" to 5/16"
1/16"- 5/32"
  • Pipe and Structural
  • Gunsmithing
