PowerARC 280STH, view 1
PowerARC 280STH, view 2
PowerARC 280STH, view 3
PowerARC 280STH, view 4
SKU# PA-280STH
PowerARC 280STH
$1,189.00
PowerARC 280STH
SKU# PA-280STH
  • Unit Weight: 60 lb
  • Shipping Weight: 75 lb
PowerARC 280STH
The Everlast PowerARC 280STH is built for heavy-duty Stick and DC TIG welding, day in and day out. With up to 250 amps of DC Stick output and 280 amps of DC TIG output, it’s a go-to machine for pipe welding and structural fabrication, whether you’re fitting pipe in the shop or running Stick in the field.
In Stick mode, the 280STH delivers a stable arc across a wide range of electrodes. Adjustable Hot Start and Arc Force let you dial in the arc for E6010 and E6011, general-purpose electrodes such as E6013 and E7014, low-hydrogen E7018, and stainless electrodes such as 309L and 316L. A built-in voltage reduction device (VRD) lowers open-circuit voltage in Stick mode when required by the jobsite.
In DC TIG mode, the 280STH gives you the control for precise pipe root passes and fabrication in steel, chromoly, stainless steel, and titanium. It offers pulse control up to 250 Hz, high-frequency or lift-arc starting, and 2T/4T torch control. The built-in gas solenoid handles shielding gas through adjustable preflow and postflow, so you can use a torch without a manual gas valve.
15,000 Watts Surge Rating
TIG Operation:
The unit features DC TIG operation with both HF and Lift Starting of the Arc. The Lift start is not a live lift start, but rather must be used with a torch switch or foot pedal.
The unit features a built-in gas solenoid for TIG operation and automatic control of gas flow.
This unit employs a point-type start which may require periodic adjustment to maintain optimum DC TIG starting.
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 60 A
240V 3 Phase 50/60Hz: 30 A
240V 1 Phase 50/60Hz: 48 A
240V 3 Phase 50/60Hz: 24 A
Stick Duty Cycle 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/30V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/28V Rated Output
Stick Duty Cycle 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/30V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/28V Rated Output
Stick Output Range 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 250 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 10.2 to 30 Volts
Stick Output Range 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz Stick Amp DC Output Range: 5 to 250 Amps
240V 3 Phase 50/60Hz Stick Volt DC Output Range: 10.2 to 30 Volts
70V
Hot Start
Adjustable
Hot Start Time
Adjustable
Arc Force
Adjustable
Voltage Reduction (VRD)
Anti-Stick Protection
Stick Pulse
Functions with Remote
PowerSet Simplified Pro Setup
Carbon Arc Capable
3/16"
TIG Function
Built In Gas Valve Standard Torch
Recommended Range of Welding Rod Diameters*:
1/16"- 3/16"
*Range of welding rod diameters is based on welding rod type and manufacturer's actual recommendations. Always consult manufacturer's recommendations for Amp range and minimum/maximum welding capability of each rod type.
.07" to 3/8"
.07" to 3/8"
  • Rail Car Industry
  • Pipe and Structural
Downloads
