PowerARC 300ST, view 1
PowerARC 300ST, view 2
PowerARC 300ST, view 3
PowerARC 300ST, view 4
SKU# PA-300ST
PowerARC 300ST
$849.00
$779.00
Save - $70.00
PowerARC 300ST
SKU# PA-300ST
  • Unit Weight: 60 lb
  • Shipping Weight: 75 lb
PowerARC 300ST
The PowerARC 300ST is a compact, heavy-duty 300A Stick welder built for demanding jobsite and shop work. Part of the Everlast lineup since 2010, it delivers a stable arc with a wide range of electrodes, including cellulosic rods such as E6010. It also offers basic DC Lift Start TIG for an optional TIG rig setup, giving welders another option for work such as pipe root passes and structural fabrication.
  1. Arc force control in stick mode improves arc performance and wet-in
  2. Hot start increases arc striking current to improve starting in less than ideal situations
  3. Lift-arc DC TIG can be fitted with an optional gas-valve torch to weld TIG where basic TIG welding is required on steel and stainless
  4. One phase 220/240V input.
9,500 Watts Surge Rating
TIG Operation:
The unit features DC TIG operation. It is Lift Start only and uses a traditional gas-valve type TIG rig. The torch gas line is connected directly to the operational regulator. Gas flow is manually controlled via the torch valve.
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 60 A
240V 3 Phase 50/60Hz: 46.8 A
240V 1 Phase 50/60Hz: 46.8 A
240V 3 Phase 50/60Hz: 32 A
Stick Duty Cycle 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 300A/32V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/30V Rated Output
Stick Duty Cycle 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 300A/32V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/30V Rated Output
Stick Output Range 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 300 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 32 Volts
Stick Output Range 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz Stick Amp DC Output Range: 20 to 300 Amps
240V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 32 Volts
80V
Hot Start
Adjustable
Hot Start Time
Fixed
Arc Force
Adjustable
Voltage Reduction (VRD)
Anti-Stick Protection
Stick Pulse
Functions with Remote
PowerSet Simplified Pro Setup
Carbon Arc Capable
3/16"-1/4"
TIG Function
TIG Rig with Gas Valve Torch
Other Stick Functions
TIG Rig torch and regulator are optional
Recommended Range of Welding Rod Diameters*:
1/16"- 3/16" (up to 1/4" on some rod types and brands)
*Range of welding rod diameters is based on welding rod type and manufacturer's actual recommendations. Always consult manufacturer's recommendations for Amp range and minimum/maximum welding capability of each rod type.
.040" to 1/4"
.040" to 1/4"
  • Rail Car Industry
  • Pipe and Structural
  • Structural
