PowerARC 300ST 480V 3 Phase
SKU# PA-300-480
- Unit Weight: 60 lb
- Shipping Weight: 75 lb
- Unit Dimensions: 9.75 in × 25 in × 15 in
The PowerARC 300ST is a compact, heavy-duty 300A Stick welder built for demanding jobsite and shop work. Part of the Everlast lineup since 2010, it delivers a stable arc with a wide range of electrodes, including cellulosic rods such as E6010. It also offers basic DC Lift Start TIG for an optional TIG rig setup, giving welders another option for work such as pipe root passes and structural fabrication.
- Arc force control in stick mode improves arc performance and wet-in
- Hot start increases arc striking current to improve starting in less than ideal situations
- Lift-arc DC TIG can be fitted with an optional gas-valve torch to weld TIG where basic TIG welding is required on steel and stainless
- Three phase 480V input.
15,500 Watts Surge Rating
TIG Operation:
The unit features DC TIG operation. It is Lift Start only and uses a traditional gas-valve type TIG rig. The torch gas line is connected directly to the operational regulator. Gas flow is manually controlled via the torch valve.
| Voltage/Phase | 480V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 480V 3 Phase 50/60Hz: 18.3 A
| Rated Effective Amps (I1Eff) | 480V 3 Phase 50/60Hz: 15 A
| LCD Screen | No
| Memory | No
| Stick Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 300A/32V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/30V Rated Output
| Stick Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz Stick Amp DC Output Range: 20 to 300 Amps
480V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 32 Volts
| Hot Start Time | Fixed
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
| Maximum Stick Rod Diameter (Recommended, may vary by mfgr. and type) | 3/16"-1/4"
| Other Stick Functions | TIG Rig torch and regulator are optional
| TIG Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 300A/32V Rated Output
| TIG Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz TIG Amp DC Output Range: 20 to 300 Amps
480V 3 Phase 50/60Hz TIG Volt DC Output Range: 20.8 to 32 Volts
| Important TIG Specification Notes | This unit features DC Lift Start TIG. The gas-valve torch and regulator required to weld in TIG mode are optional. Purchase from the add on accessories at check out. It is possible that other fittings may be required to connect the torch to the regulator.
Recommended Range of Welding Rod Diameters*:
1/16"- 3/16" (up to 1/4" on some rod types and brands)
*Range of welding rod diameters is based on welding rod type and manufacturer's actual recommendations. Always consult manufacturer's recommendations for Amp range and minimum/maximum welding capability of each rod type.
.040" to 1/4"
.040" to 1/4"
- Rail Car Industry
- Pipe and Structural
- Structural
- 6.5 Ft. power input cable (No plug included due to 3 phase input)
