PowerPlasma 102i (3Ph 240V/480V), view 1
PowerPlasma 102i (3Ph 240V/480V), view 2
PowerPlasma 102i (3Ph 240V/480V), view 3
PowerPlasma 102i (3Ph 240V/480V), view 4
PowerPlasma 102i (3Ph 240V/480V), view 5
SKU# PP-102I-240-480-3
Hand or CNC Cutting
$1,999.00
$1,899.00
Save - $100.00
Hand or CNC Cutting
  • Unit Weight: 58 lb
  • Shipping Weight: 67 lb
The PowerPlasma 102i is a professional plasma cutter that delivers quality cutting performance for professional shops that regularly cut 1" and greater material by hand. This unit can actually severe much thicker, but it is ready to tackle hand cutting chores anywhere thick plate is found. This unit only operates with 220/240V or 480V 3 phase input. It does not operate on 1 phase input.
  1. 240V 3 phase or 480V 3 phase input power
  2. CNC Port built in
  3. Blow-Back Style, Pilot Arc Hand Cutting Torch
  7. Gouge function
Generator Requirements*:
  2. 17,500 Surge Watts operating on 240V 3 phase
  3. 16,500 Surge Watts operating on 480V 3 phase
Important Note:
480V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz: 40 A
480V 3 Phase 50/60Hz: 18 A
240V 3 Phase 50/60Hz: 32 A
480V 3 Phase 50/60Hz: 15 A
Plasma Duty Cycle 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/120V Rated Output
Plasma Duty Cycle 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/120V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/112V Rated Output
310V
Arc Start Type
Blowback, Piston Type
Torch Type
iPT 100 Hand Torch
CNC Capable/Ready
Yes, with optional Torch
Gouging Capable
Gouging Duties
Heavy
Drag Cutting
Post Flow Timer
Adjustable
Parts-In-Place Safety Cut Out
Recommended Flow Rate (Air)
9 CFH @ 90 PSI
Maximum Supply Pressure
90 PSI
Compressor Built In
60 Gallon
65-75
Remote
Tip Saver Function
Location of CNC Port
Rear
CNC Port Type
WEiPu SP21 12 pin
Torch Connector Type
Central Euro
  1. Up to 1 1/4 " daily use
  2. Up to 1 5/16 " clean cut
  3. Up to 1 1/2" severance cut
  4. Pierce up to 3/4"
Units are supplied with a starter set of consumables intended primarily for cutting in the 90–100 amp range. While there is effectively no practical minimum material thickness that can be cut, standard higher-amperage tips may produce an unnecessarily wide kerf on very thin material. For best results on lighter gauges, use a consumable with a smaller orifice matched to the required cutting amperage.
  1. Up to 7/8" daily use
  2. Up to 1 1/8" clean cut (edge start)
  3. Pierce up to 3/4"
  • Aerospace
  • Pipe and Structural
