PowerPro 256D, view 1
PowerPro 256D, view 2
PowerPro 256D, view 3
PowerPro 256D, view 4
SKU# PP-256D
PowerPro 256D
Digital AC/DC
$2,999.00
$2,199.00
Save - $800.00
PowerPro 256D
Digital AC/DC
SKU# PP-256D
  • Unit Weight: 67 lb
  • Shipping Weight: 101 lb
PowerPro 256D
The digitally controlled Everlast PowerPro 256D combines AC/DC Pulse TIG welding, Stick welding, and plasma cutting in one versatile unit. Designed for professionals who need precise control across multiple processes, it is well suited for light commercial fabrication, portable repairs, and general maintenance.
For Stick welding, the Voltage Reduction Device (VRD) lowers open-circuit voltage when the unit is not welding, helping reduce the risk of electric shock and supporting use on jobsites that require this feature. For TIG welding, advanced AC pulse and waveform controls let you fine-tune arc performance for demanding aluminum applications.
The integrated plasma cutter handles steel plate up to 5/8" thick for routine cutting and provides severance capacity up to 1". This gives you the cutting power to prepare material for a wide range of welding jobs and tackle thicker plate when needed.
Whether you need to cut material, complete a field repair, or make a precise TIG weld, the PowerPro 256D gives you the flexibility to handle a wide range of jobs.
  2. 9,500 Surge Watts
  2. E6011 use is permissible but performance may be brand dependent
240V 1 Phase 50/60Hz: 37 A
240V 1 Phase 50/60Hz: 30 A
9 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 20 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 3 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 20 Volts
70V
TIG Start Type
Lift Start With Remote
HF Start with Point Gap Start
Start Amp Range AC
5-250A
Start Amp Range DC
3-250A
End Amp Range AC
5-250A
End Amp Range DC
3-250A
0-10 Seconds
0-25 Seconds
0-10 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-250 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
10-90%
Pulse Amperage
3-99% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
10-90% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Sine
.005" to 1/2"
.005" to 1/2"
.010"- 1/2" (with advanced AC Pulse for maximum penetration)
1/16"- 5/32" (3/16" some types, depending upon manufacturer)
  1. Up to 5/8" daily use
  2. Up to 3/4" clean cut
  3. Up to 1" severance cut
  4. Pierce up to 5/8"
  1. NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
  • Aerospace
  • Rail Car Industry
  • Pipe and Structural
