PowerTIG 200 DV
SKU# PT-200DV
- Unit Weight: 56 lb
- Unit Dimensions: 9.5 in × 25 in × 14.63 in
The PowerTIG 200DV is perfect for beginners and professionals who want a simple to use TIG welder without compromising welding performance. While the PowerTIG 200DV is not the most advanced unit Everlast offers, it checks all the boxes for the essentials needed for welding most daily shop chores up to 1/4". It features both AC/ DC TIG Pulse TIG welding capability, it also features stick welding capability as well. As a 200A TIG welder, the unit offers AC Frequency and Balance control in AC mode. These two features are essential to getting the most performance out of your machine. If welding at the limitsThe unit offers a pulse function as well for TIG in both AC and DC modes. The auto-sensing dual voltage 120/240V input allows the user to take the unit to the jobsite where there may not be 240V available. For stick performance, the unit performs well with titania and iron powder fluxed rods.
- Dual Voltage 120V/240V
- High TIG Duty Cycle: 200A @60%
- Pulse TIG up to 150Hz
- AC Frequency and Balance Control
- 8500 Surge Watts
- Not for use with E6010 and most cellulosic rods
- E6011 use is permissible
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 35 A
240V 1 Phase 50/60Hz: 31 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 24 A
240V 1 Phase 50/60Hz: 23 A
| LCD Screen | No
| Memory | No
| Fan | On-Arc
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/15V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/18V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 15 Volts
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 15 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 200 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 18 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 200 Amps
| Open Circuit Voltage (OCV) | 75V
| Start Amp Range AC | Fixed
| Start Amp Range DC | Fixed
| End Amp Range AC | Fixed
| End Amp Range DC | Fixed
| Up-Slope Time | Fixed
| TIG Pulse | AC
| AC Pulse Type | Standard
| DC Pulse Frequency | 0-150 Hz
| AC Pulse Frequency | 0-150 Hz
| AC Frequency | 20-250 Hz
| AC Balance | 20-80% of Positive Electrode
| AC Wave Forms | Square
| Other Functions | Dual Voltage
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 100A/24V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/23.2V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 160A/26.4V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 130A/25.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 100A/24V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 24 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 160 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 26.4 Volts
| Hot Start | Fixed
| Hot Start Time | Fixed
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Output | AC/DC
| Functions with Remote | No
Use 6011 for best results
| Important Stick Specification Notes | Not for E6010 use.
.007" to 5/16"
.007" to 5/16"
.025"- 1/4"
1/16"- 5/32"
- Consumable Starter Kit
- 240V-120V Power Adapter
- 6 Ft. Power cable with NEMA 6-50P Plug
