PowerTIG 200 DV-Welding Cart 375LF, view 1
PowerTIG 200 DV-Welding Cart 375LF, view 2
PowerTIG 200 DV-Welding Cart 375LF, view 3
PowerTIG 200 DV-Welding Cart 375LF, view 4
PowerTIG 200 DV-Welding Cart 375LF, view 5
SKU# PT-200DV-PC375LF
Analog AC/DC
$1,579.00
$1,268.00
Save - $311.00
Analog AC/DC
The PowerTIG 200DV with water cooler package includes everything standard with the PowerTIG 200DV package, but also includes the PowerCart 375LF, which is designed to neatly fit and secure the PowerTIG 200DV to the cart.
  2. 8500 Surge Watts
  2. E6011 use is permissible
120V 1 Phase 50/60Hz
On-Arc
Cooler Control
Runs Continuously
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/15V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/18V Rated Output
120V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 15 Volts
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 15 Volts
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 200 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 18 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 200 Amps
75V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
Fixed
Start Amp Range DC
Fixed
End Amp Range AC
Fixed
End Amp Range DC
Fixed
0-10 Seconds
0-25 Seconds
Fixed
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
150 Hz
AC Pulse Frequency
0-150 Hz
10-90%
Pulse Amperage
5-95% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
20-80% of Positive Electrode
AC Wave Forms
Square
Important TIG Specification Notes
Dual Voltage
.007" to 5/16"
.007" to 5/16"
.025"- 1/4"
1/16"- 5/32"
