PowerTIG 200DV & PowerCart 375LF
SKU# PT-200DV-PC375LF
The PowerTIG 200DV with water cooler package includes everything standard with the PowerTIG 200DV package, but also includes the PowerCart 375LF, which is designed to neatly fit and secure the PowerTIG 200DV to the cart.
- 8500 Surge Watts
- Not for use with E6010 and most cellulosic rods
- E6011 use is permissible
| LCD Screen | No
| Memory | No
| Fan | On-Arc
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/15V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/18V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 15 Volts
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 15 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 200 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 18 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 200 Amps
| Open Circuit Voltage (OCV) | 75V
| Start Amp Range AC | Fixed
| Start Amp Range DC | Fixed
| End Amp Range AC | Fixed
| End Amp Range DC | Fixed
| Up-Slope Time | Fixed
| TIG Pulse | AC
| AC Pulse Type | Standard
| DC Pulse Frequency | 150 Hz
| AC Pulse Frequency | 0-150 Hz
| AC Frequency | 20-250 Hz
| AC Balance | 20-80% of Positive Electrode
| AC Wave Forms | Square
| Important TIG Specification Notes | Dual Voltage
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 100A/24V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/23.2V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 160A/26.4V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 130A/25.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 100A/24V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 24 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 160 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 26.4 Volts
| Hot Start | Fixed
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Output | AC/DC
| Functions with Remote | No
Use 6011 for best results
| Important Stick Specification Notes | Not for E6010 use.
.007" to 5/16"
.007" to 5/16"
.025"- 1/4"
1/16"- 5/32"
