PowerTIG 210EXT
SKU# PT-210EXT
- Unit Weight: 62 lb
- Unit Dimensions: 9.25 in × 25 in × 15 in
Built for professionals and approachable for beginners, the Everlast PowerTIG 210EXT brings versatile AC/DC TIG and Stick welding to fabrication shops, small businesses, home garages and portable repair work. Its compact, lightweight IGBT inverter design makes it easy to take wherever TIG welding is needed, while digital microprocessor control delivers a stable arc, precise adjustments and repeatable settings. Intuitive controls simplify setup, and programmable memory lets you save your favorite settings for the next job.
For aluminum welding, three AC waveforms: Advanced Square, Soft Square and Triangular. These wave forms combine with adjustable AC frequency and balance to tailor the arc to the application. Standard pulse adds heat control, while Advanced Pulse alternates between AC and DC electrode-negative output to help control the puddle on thin aluminum and increase penetration on thicker sections. Adjustable Hot Start and Arc Force extend that versatility to Stick welding, giving you control for fabrication, maintenance and general repairs.
- 120/240V operation for go anywhere performance
- Low AC and DC TIG Starting Amps
- Smooth, stable arc in TIG
- Solid state HV Start removes the issue of point gap maintenance for traditional HF starting
- 60% Duty cycle at maximum ouput extends operation times for true industrial settings
- Advanced AC pulse increases range of AC TIG performance by using a mixed/hybrid AC and DC negative pulse for maximum penetration
- 3 AC wave forms: Advanced Square, Soft Square and Triangular for improved Aluminum welding quality
- Fan-on-arc for quieter operation
- 7,500 Surge Watts
- Not for use with E6010 stick welding rods
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 26.8 A
240V 1 Phase 50/60Hz: 23.5 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 21 A
240V 1 Phase 50/60Hz: 19 A
| LCD Screen | No
| Memory | 9 Programs
| Fan | On-Arc
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/15V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 210A/18.4V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 170A/16.8V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 15 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 3 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 15 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 210 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 18.4 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 3 to 210 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 18.4 Volts
| Start Amp Range AC | 5-(125)210A
| Start Amp Range DC | 3-(125)210A
| End Amp Range AC | 5-(125)210A
| End Amp Range DC | 3-(125)210A
| TIG Pulse | AC
| AC Pulse Type | Standard
Advanced
| AC Frequency | 20-250 Hz
| AC Wave Forms | Square
Soft Square
Triangular
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/24V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/26.4V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/25.2V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 24 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 160 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 26.4 Volts
| Open Circuit Voltage (OCV) | 80 (<24 with VRD)V
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
Use 6011 for best results
| Important Stick Specification Notes | E6011 results may vary with rod manufacturer. Keep a short arc or drag rod for best performance.
.007" to 5/16"
.007" to 5/16"
.025"- 1/4"
1/16"- 5/32"
- Aerospace
- Rail Car Industry
- 6.5 Ft. Power Input Cable with NEMA 6-50 Plug
- TIG Starter Consumable Kit
- 240V to 120V Pigtail Power Adapter
