PowerTIG 250EX  Cooler and Cart Bundle Package, view 1
Power TIG 250EX Front View
PowerCool 375 Front
PowerTIG 250EX  Cooler and Cart Bundle Package, view 4
Accessory Package View
PowerCool 375 Front
SKU# PT-250EX-BNDL
Analog AC/DC
$2,437.00
$2,024.00
Save - $413.00
Analog AC/DC
SKU# PT-250EX-BNDL
This Bundle package includes the PowerTIG 250EX, all of the standard accessories for the PowerTIG 250EX, PowerCool W375 water-cooler and the PowerCart 375LF. The PowerTIG 250EX and PowerCool W375 Water Cooler pair seamlessly together as an integrated system.
The PowerTIG 250EX stacks securely on top of the PowerCool W375 using a system of slide-on interlocking tabs. For a more permanent installation, the two units can also be fastened together using the side-panel screws and bracket, keeping them firmly connected during use and transport.
The 240V PowerCool W375 plugs directly into a dedicated power outlet on the rear of the PowerTIG 250EX, providing a clean and convenient installation without the need for a separate 240V wall outlet.
The PowerCart 375LF is tailored specifically to the frame of the cooler and welder package. It fits neatly without being undersized. A full size cylinder can be loaded as well. When the cart needs to resist rolling, two heavy duty locking casters lock the wheels on the front. The large 10" rear wheels also provide easy rolling on shop floors.
Includes:
  1. PowerTIG 250EX
  2. Standard Accessory Package
  3. PowerCool W375 Water Cooler
  4. PowerCart 375 LF
10,500 Watts Surge Rating
Warranty on packaged accessory items may vary in length. See warranty page for details.
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 40 A
240V 3 Phase 50/60Hz: 21 A
240V 1 Phase 50/60Hz: 32 A
240V 3 Phase 50/60Hz: 16 A
On-Arc
Cooler Control
Runs Continuously
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/18V Rated Output
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 18 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 250 Amps
240V 3 Phase 50/60Hz TIG Amp AC Output Range: 5 to 250 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 18 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 250 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 18 Volts
85V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
5-250A
Start Amp Range DC
5-250A
End Amp Range AC
5-250A
End Amp Range DC
5-250A
0-10 Seconds
0-25 Seconds
0-10 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-500 Hz
10-90%
Pulse Amperage
5-95% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
10-90% of Positive Electrode
AC Wave Forms
Square
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
1/16"- 5/32"
  • Pipe and Structural
