PowerTIG 250EX & W375 Cooler & Cart 375LF & Nova Kit (Bundle)
SKU# PT-250EX-BNDL
This Bundle package includes the PowerTIG 250EX, all of the standard accessories for the PowerTIG 250EX, PowerCool W375 water-cooler and the PowerCart 375LF. The PowerTIG 250EX and PowerCool W375 Water Cooler pair seamlessly together as an integrated system.
The PowerTIG 250EX stacks securely on top of the PowerCool W375 using a system of slide-on interlocking tabs. For a more permanent installation, the two units can also be fastened together using the side-panel screws and bracket, keeping them firmly connected during use and transport.
The 240V PowerCool W375 plugs directly into a dedicated power outlet on the rear of the PowerTIG 250EX, providing a clean and convenient installation without the need for a separate 240V wall outlet.
The PowerCart 375LF is tailored specifically to the frame of the cooler and welder package. It fits neatly without being undersized. A full size cylinder can be loaded as well. When the cart needs to resist rolling, two heavy duty locking casters lock the wheels on the front. The large 10" rear wheels also provide easy rolling on shop floors.
Includes:
- PowerTIG 250EX
- Standard Accessory Package
- PowerCool W375 Water Cooler
- PowerCart 375 LF
10,500 Watts Surge Rating
Warranty on packaged accessory items may vary in length. See warranty page for details.
240V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 40 A
240V 3 Phase 50/60Hz: 21 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 32 A
240V 3 Phase 50/60Hz: 16 A
| LCD Screen | No
| Memory | No
| Fan | On-Arc
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
| TIG Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/18V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 18 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 250 Amps
| TIG Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz TIG Amp AC Output Range: 5 to 250 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 18 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 250 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 18 Volts
| Open Circuit Voltage (OCV) | 85V
| Start Amp Range AC | 5-250A
| Start Amp Range DC | 5-250A
| End Amp Range AC | 5-250A
| End Amp Range DC | 5-250A
| TIG Pulse | AC
| AC Pulse Type | Standard
| AC Frequency | 20-250 Hz
| AC Balance | 10-90% of Positive Electrode
| AC Wave Forms | Square
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 200A/28V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/26.5V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/25.2V Rated Output
| Stick Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 200A/28V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/26.5V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/25.2V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 200 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 28 Volts
| Stick Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz Stick Amp DC Output Range: 5 to 200 Amps
240V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 28 Volts
| Hot Start Time | Fixed
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
Use 6011 for best results
| Important Stick Specification Notes | Not for E6010 use.
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
1/16"- 5/32"
- Pipe and Structural
- PowerCool W375 (240V)
- Consumable Starter Kit
- 6 Foot Power Cord (No Plug Included)
