PowerTIG 250EX Cooler Package
PowerTIG 315 LX Front View
PowerCool 375 Front
PowerTIG 315 LX Accessory Package
PowerCool 375 Front
SKU# PT-315LX-PC-375
PowerTIG 315 LX Water Cooler Package
Analog AC/DC
$2,648.00
$2,048.00
Save - $600.00
Analog AC/DC
This combination package includes the PowerTIG 315 LX and PowerCool 401 Water Cooler, designed to pair together as an integrated system.
The PowerTIG 315LX stacks securely on top of the PowerCool 401 using a system of slide-on interlocking tabs. For a more permanent installation, the two units can also be fastened together using the side-panel screws and bracket, keeping them firmly connected during use and transport.
The 240V PowerCool 401 plugs directly into a dedicated power outlet on the rear of the PowerTIG 315 LX, providing a clean and convenient installation without the need for a separate 240V wall outlet.
This package also includes all of the standard accessories supplied with the PowerTIG 315 LX.
Generator Requirements*
  2. 13,500 Surge Watts minimum
*If generator recommendations are not followed, the warranty is void.
240V 1 Phase 50/60Hz: 53 A
240V 1 Phase 50/60Hz: 31 A
On-Arc
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 22.6 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.6 Volts
80V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
20-315A
Start Amp Range DC
5-315A
End Amp Range AC
20-315A
End Amp Range DC
5-315A
0-15 Seconds
0-30 Seconds
0-10 Seconds
0-30 Seconds
TIG Pulse
AC
AC Pulse Type
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
750 Hz
AC Pulse Frequency
500 Hz
10-90%
Pulse Amperage
5-95% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
20-80% of Positive Electrode
AC Wave Forms
Square
.015" to 1/2"
.015" to 1/2"
.030"- 1/2"
*Capability varies based on skill, weldment size, joint prep and general welding knowledge. The maximum limit is a practical recommended single pass limit based on the industry standard of performing thicker welds with multiple passes on properly prepared joints. A multi-pass weld may be required to achieve the thickest maximum weld. All figures are approximate.
1/16"- 3/16"
  • Rail Car Industry
  • Production
