PowerTIG 315LX Cooler Cart Package
PowerTIG 315 LX Front View
PowerCool 375 Front View
PowerCart 375LF front view
PowerTIG 315 LX Accessory Package
SKU# PT-315LX- BNDLE
PowerTIG 315 LX Cooler and Cart Bundle Package
Analog AC/DC
$2,797.00
$2,250.00
Save - $547.00
Analog AC/DC
This Bundle package includes the PowerTIG 315 LX, all of the standard accessories for the PowerTIG 315 LX, PowerCool W375 water-cooler and the PowerCart 375LF. The PowerTIG 315LX and PowerCool W375 Water Cooler pair seamlessly together as an integrated system.
The PowerTIG 315LX stacks securely on top of the PowerCool 375 using a system of slide-on interlocking tabs. For a more permanent installation, the two units can also be fastened together using the side-panel screws and bracket, keeping them firmly connected during use and transport.
The 240V PowerCool 375 plugs directly into a dedicated power outlet on the rear of the PowerTIG 315 LX, providing a clean and convenient installation without the need for a separate 240V wall outlet.
The PowerCart 375LF is tailored specifically to the frame of the cooler and welder package. It fits neatly without being undersized. A full size cylinder can be loaded as well. When the cart needs to resist rolling, two heavy duty locking casters lock the wheels on the front. The large 10" rear wheels also provide easy rolling on shop floors.
Includes:
  1. PowerTIG 315 LX
  2. Accessory Package
  3. PowerCool W375 Water Cooler
  4. PowerCart 375 LF
Generator Requirements*
  2. 13,500 Surge Watts minimum
*If generator recommendations are not followed, the warranty is void.
Warranty on accessories in the package may vary.
240V 1 Phase 50/60Hz: 53 A
240V 1 Phase 50/60Hz: 31 A
On-Arc
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 22.6 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.6 Volts
80V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
20-315A
Start Amp Range DC
5-315A
End Amp Range AC
20-315A
End Amp Range DC
5-315A
0-15 Seconds
0-30 Seconds
0-10 Seconds
0-30 Seconds
TIG Pulse
AC
AC Pulse Type
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-750 Hz
AC Pulse Frequency
0-500 Hz
10-90%
Pulse Amperage
5-95% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
20-80% of Positive Electrode
AC Wave Forms
Square
.015" to 1/2"
.015" to 1/2"
.030"- 1/2"
*Capability varies based on skill, weldment size, joint prep and general welding knowledge. The maximum limit is a practical recommended single pass limit based on the industry standard of performing thicker welds with multiple passes on properly prepared joints. A multi-pass weld may be required to achieve the thickest maximum weld. All figures are approximate.
1/16"- 3/16"
  • Rail Car Industry
  • Production
