PowerTIG 315LX, view 1
PowerTIG 315LX, view 2
PowerTIG 315 LX Accessory Package
PowerTIG 315LX, view 4
PowerTIG 315 LX Rear View
SKU# PT-315LX
PowerTIG 315LX
Analog AC/DC
$1,920.00
$1,550.00
Save - $370.00
PowerTIG 315LX
Analog AC/DC
SKU# PT-315LX
  • Unit Weight: 72 lb
  • Shipping Weight: 87 lb
  • Unit Dimensions: 9.5 in × 25 in × 15 in
PowerTIG 315LX
The PowerTIG 315 LX is designed for the serious professional welder who wants to set up the machine and get to work without navigating complicated menus or unnecessary settings. Its traditional knob-style controls provide a familiar, intuitive interface while offering the performance and adjustability required for demanding commercial and industrial applications.
Built with production environments in mind, the PowerTIG 315 LX is well suited for repetitive welding operations where consistency, reliability, and ease of setup are essential. Once the proper parameters are established, operators can focus on producing the same high-quality welds part after part, shift after shift.
For aluminum welding, adjustable AC Balance and AC Frequency controls provide the flexibility needed to fine-tune arc characteristics, cleaning action, penetration, and overall weld performance. For even greater control over heat input and weld appearance, the built-in pulse function operates in both AC and DC TIG modes.
Straightforward to operate, powerful, and built for dependable professional service, the PowerTIG 315 LX is a true production-ready workhorse designed to deliver the pay check.
  2. 13,500 Surge Watts
  2. E6011 use is permissible
240V 1 Phase 50/60Hz: 53 A
240V 1 Phase 50/60Hz: 31 A
On-Arc
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 22.6 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.6 Volts
80V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
20-315A
Start Amp Range DC
5-315A
End Amp Range AC
20-315A
End Amp Range DC
5-315A
0-10 Seconds
0-30 Seconds
0-15 Seconds
0-30 Seconds
TIG Pulse
AC
AC Pulse Type
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-750 Hz
AC Pulse Frequency
0-500 Hz
10-90%
Pulse Amperage
5-95% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
20-80% of Positive Electrode
AC Wave Forms
Square
.015" to 1/2"
.015" to 1/2"
.030"- 1/2"
*Capability varies based on skill, weldment size, joint prep and general welding knowledge. The maximum limit is a practical recommended single pass limit based on the industry standard of performing thicker welds with multiple passes on properly prepared joints. A multi-pass weld may be required to achieve the thickest maximum weld. All figures are approximate.
1/16"- 3/16"
  • Rail Car Industry
  • Production
