PowerTIG 315LX & W375 Cooler Package
SKU# PT-315LX-PC-375
This combination package includes the PowerTIG 315 LX and PowerCool 401 Water Cooler, designed to pair together as an integrated system.
The PowerTIG 315LX stacks securely on top of the PowerCool 401 using a system of slide-on interlocking tabs. For a more permanent installation, the two units can also be fastened together using the side-panel screws and bracket, keeping them firmly connected during use and transport.
The 240V PowerCool 401 plugs directly into a dedicated power outlet on the rear of the PowerTIG 315 LX, providing a clean and convenient installation without the need for a separate 240V wall outlet.
This package also includes all of the standard accessories supplied with the PowerTIG 315 LX.
Generator Requirements*
- 13,500 Surge Watts minimum
*If generator recommendations are not followed, the warranty is void.
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 53 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 31 A
| LCD Screen | No
| Memory | No
| Fan | On-Arc
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/22.6V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 22.6 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.6 Volts
| TIG Start Type | HV/HF Solid State (Touchless) Start
Lift Start With Remote
| Start Amp Range AC | 20-315A
| Start Amp Range DC | 5-315A
| End Amp Range AC | 20-315A
| End Amp Range DC | 5-315A
| Pre-Flow Time | 0-15 Seconds
| Down-Slope Time | 0-30 Seconds
| TIG Pulse | DC
AC
| AC Pulse Type | Standard
| DC Pulse Frequency | 750 Hz
| AC Pulse Frequency | 500 Hz
| AC Frequency | 20-250 Hz
| AC Balance | 20-80% of Positive Electrode
| AC Wave Forms | Square
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 250A/30V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 320 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 30 Volts
| Hot Start Time | Fixed
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
.015" to 1/2"
.015" to 1/2"
.030"- 1/2"
*Capability varies based on skill, weldment size, joint prep and general welding knowledge. The maximum limit is a practical recommended single pass limit based on the industry standard of performing thicker welds with multiple passes on properly prepared joints. A multi-pass weld may be required to achieve the thickest maximum weld. All figures are approximate.
1/16"- 3/16"
- Rail Car Industry
- Production
- 2T/4T Torch Switch for TIG welders 7 pin female 15 Ft.
- PowerCool W375 (240V)
- Consumable Starter Kit
- 6 ft. Power Input Cable with NEMA 6-50 Plug (Plug not included on Optional 3 phase units)
