PowerTIG 400EXT
SKU# PT-400EXT
- Unit Weight: 105 lb
- Unit Dimensions: 11.5 in × 25 in × 24 in
Built for professional shops that need serious welding power, the PowerTIG 400EXT is the most powerful model in Everlast’s PowerTIG series. It delivers a full 400A of AC/DC TIG output on single-phase power at a 35% duty cycle, providing the capacity to tackle thick plate and heavy weldments. In Stick mode, it produces 315A at a 35% duty cycle and supports electrodes up to 1/4" for demanding fabrication and repair.
Advanced AC Pulse, 4 AC wave forms, and Adjustable AC frequency enhances aluminum welding capability helping you take on a wide variety of Aluminum welding applications. The 400A high output is balanced by low-end TIG capability, giving you control for lighter work.
The familiar digital features, controls and layout of the popular EXT series make upgrading to greater capacity straightforward for shops already using an EXT model. From heavy fabrication to everyday repairs, the PowerTIG 400EXT brings power and versatility to your shop. Just add a power plug, shielding gas and tungsten, and you’re ready to weld.
Key Features
- Operate on either 220/ 240V 1 phase or 220/240V 3 phase for versatile performance options
- 5A DC Start and 10A AC Start for excellent arc starts on thinner materials (with small .040" diameter tungsten)
- Smooth, stable arc in TIG delivers a higher quality weld
- Solid state HV Start removes the issue of point gap maintenance for traditional HF starting
- 60% Duty cycle at maximum ouput, regardless of phase the unit is operated on extends operation times for true industrial settings
- Advanced AC pulse increases range of AC TIG performance by using a mixed/hybrid AC and DC negative pulse for maximum penetration
- 4 Adjustable AC Wave Forms: Advanced Square, Soft Square, Triangular and Sine Wave for improved Aluminum welding control
- Fan-on-arc for quieter operation
- 15,500 Surge Watts on 1 phase 240V
- E6010 mode operates best with a short arc
240V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 79 A
240V 3 Phase 50/60Hz: 39 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 48 A
240V 3 Phase 50/60Hz: 24 A
| LCD Screen | No
| Memory | 9 Programs
| Fan | On-Arc
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 400A/26V Rated Output
| TIG Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 400A/26V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/22.6V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/20V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 26 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
| TIG Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 22.8 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
| Start Amp Range AC | 10-400A
| Start Amp Range DC | 5-400A
| End Amp Range AC | 10-400A
| End Amp Range DC | 5-400A
| Post-Flow Time | 0-50 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Advanced
| AC Frequency | 20-250 Hz
| AC Wave Forms | Square
Soft Square
Triangular
Sine
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 315A/32.6V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/30V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 315A/32.6V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/28V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 315 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 32.6 Volts
| Stick Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz Stick Amp DC Output Range: 20 to 315 Amps
240V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 32.6 Volts
| Open Circuit Voltage (OCV) | 70 (<24 with VRD)V
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
| E6010/Cellulose Rod (Electrode) Capable | Use 6011 for best results
Yes, but limited to short arc
| Important Stick Specification Notes | E6010 results may vary with rod manufacturer. Keep a short arc or drag rod for best performance.
.015" to 1/2"+
.015" to 1/2"+
.025"- 1/2"+
1/16"- 1/4"
- Aerospace
- Rail Car Industry
- Pipe and Structural
- NOVA 26 Series Air-Cooled Rigid Neck TIG Torch 12.5 Ft. 25 DINSE-Type Connector (No Gas Thru)
- 6.5 Ft. Power Input Cable (Power Plug not included)
- TIG Starter Consumable Kit
