PowerTIG 400EXT 240V 1/3 ph 301 Cart and W401 Cooler Bundle Package, view 1
PowerTIG 400EXT 240V 1/3 ph 301 Cart and W401 Cooler Bundle Package, view 2
PowerTIG 400EXT 240V 1/3 ph 301 Cart and W401 Cooler Bundle Package, view 3
PowerTIG 400EXT 240V 1/3 ph 301 Cart and W401 Cooler Bundle Package, view 4
PowerTIG 400EXT 240V 1/3 ph 301 Cart and W401 Cooler Bundle Package, view 5
SKU# PT 400EXT-240V-301-W401-BUNDLE-9
Digital AC/DC
$4,627.00
$3,999.00
Save - $628.00
Digital AC/DC
The PowerTIG 400EXT (240V 1 and 3 phase model) bundle package includes the PowerCart 301LF and the PowerCool 401 water cooler. This package gives you everything that normally comes with the PowerTIG 400EXT (240V 1 and 3 phase model) including the standard accessory package. The cooler included in this package stacks securely under the PowerTIG 400EXT with a smooth, connected look. The cart is designed to hold both the welder and cooler If the cooler isn't needed, it can hold just the welder as well. The thumb screws that connect to the bottom of the cooler from under the cart and the top capture bar on the cart keep the welder and cooler from sliding around. This package is perfect for small shops and fabrication facilities that need a compact water-cooled package. Be sure to add a cover after selecting this package under the "add accessories" option to keep the welder protected when not in use.
Includes:
  1. PowerTIG 400EXT (240V 1 and 3 phase model)
  2. PowerTIG 400EXT Accessory Package
  3. PowerCart 301 Welding Cart
  4. PowerCool 401 Water Cooler
  2. 19,500 Surge Watts
  1. TIG lift start requires a remote to start arc. It is not a live lift function.
Package Notes:
  1. Each item in this package may vary in warranty length. The warranty listed for this package is only for the welder itself.
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 79 A
240V 3 Phase 50/60Hz: 39 A
240V 1 Phase 50/60Hz: 48 A
240V 3 Phase 50/60Hz: 24 A
21S
9 Programs
On-Arc
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 400A/26V Rated Output
240V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 400A/26V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/22.6V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/20V Rated Output
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 26 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
240V 3 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 26 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
70V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
10-400A
Start Amp Range DC
5-400A
End Amp Range AC
10-400A
End Amp Range DC
5-320A
0-25 Seconds
0-50 Seconds
0-25 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-250 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
5-100% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
5-90% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Sine
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
1/16"- 5/32" (3/16" some rods)
  • Aerospace
  • Rail Car Industry
