RedSabre 2000X
SKU# EV-LRS-2000X
- Unit Weight: 345 lb
- Unit Dimensions: 27 in × 50 in × 47 in
Up until recently 2000 Watt fiber lasers were all water-cooled. This meant having large, bulky equipment to move around, sometimes weighing in excess of 750 lbs. However, concepts and applications of new technologies and developments in existing technologies have allowed the size and weight to be drastically reduced for this size of welder. The new RedSabre 2000 employs a novel method of cooling compared to the water cooled design: refrigeration. The refrigerated design reduces size and weight while improving cooling so that the units can run non stop for up to 12+ hours.
The ergonomic SUP33T gun is compact and powerful with a fatigue reducing gun handle angle and a molded grip.
Notice:
- The operation of all Lasers in the USA falls under FDA restrictions, guidelines and general regulations. Additional OSHA and ANSI regulations and standards applicable to laser welding/cleaning/cutting use and applications exist.
- This is a class 4 laser, the most dangerous category. Safety Training and special laser light shielding equipment is required to use lasers for any application. Laser light radiation can be harmful, even though the wave length is not visible to the naked eye.
- Use safety glasses only matched to the wave length of this unit. Other Specialized safety equipment is also required Do not use standard cutting shades or welding helmets while using this equipment. Use only safety eye and face wear rated for 1080 nm wave lengths.
- The purchase of this laser welder may require registration with your local and state governments. Please identify any registration issues and concerns before purchase. Please contact your local and state governing authorities before purchase to inquire about registering your laser welders. Everlast does not maintain a list for each state, nor lists of general requirements for registration.
- The use of a laser in your business may require you to follow additional ANSI guidelines separate from the use of regular arc welders. It may also require special training and certifications that require additional investment and costs. In businesses with employees, you may be required to appoint a Laser Safety Officer with completed training and certification and additionally train individual operators and nearby individuals in laser safety and use.
- Contact independent laser safety certification companies for details and pricing of training. Most companies offer online certification, with some offering in person training as well. Prices vary for certification.
- Check with your insurance company to make sure that the use of a laser welder in your facility is covered if training and certifications are in place.
| Gun Model Type | SUP33T
| Laser Processes | Weld
Clean/Derust
Weld Clean
Cut
| Gun Operation and Programming | Single Scan
| Maximum Wattage Output | 2000W
| Cooling | Refrigerated
| Wire Feed Included | Yes
| Wire Feeder Type | Single Spool
| Optional Feeder Type | Double Spools
| Class Laser | 4
Minimum & Maximum:
- Maximum Weld Mild/Stainless Steel: 6.0mm (Single Pass)
- Maximum Weld Aluminum: 4.5 mm (Single Pass)
- Maximum Weld Copper: 3.0 mm (Single Pass)
- Maximum Cut Steel: 6.0 mm (Single Pass)
- Maximum Cut Aluminum: 5.0 mm (Single Pass)
- Nozzle Kit
- Wire Guide Tip Kit
- Wire Feed Tubes
- FT80 Focus Tube
- D18T2 Protective Lens Kit
- F800 Focus Lens
- Single Liner Bracket Arm
- Gas line (customer provides their own 1/4 in barb fitting)
- Communication Cable
- Door Safety Switch
- Allen Wrench Set
- Wrenches
- Laser Safety Goggles
- Laser Safety Face Shield
