Storm 215C, view 1
Storm 215C, view 2
Storm 215C, view 3
Storm 215C, view 4
Storm 215C, view 5
Storm 215C, view 6
Storm 215C, view 1
Storm 215C, view 2
Storm 215C, view 3
Storm 215C, view 4
Storm 215C, view 5
Storm 215C, view 6
SKU# STM-215C
Storm 215C
MIG
$1,769.00
$1,375.00
Save - $394.00
Storm 215C
MIG
SKU# STM-215C
  • Unit Weight: 60 lb
  • Shipping Weight: 91 lb
  • Unit Dimensions: 9.75 in × 26 in × 15 in
Storm 215C
The Everlast Storm 215C combines MIG welding, Stick welding, and Plasma cutting in one compact machine built for fabrication and portable repair. With outputs of 200A MIG, 160A Stick, and 40A plasma, each rated at a 35% duty cycle at maximum output, the inverter-based design delivers versatile performance for home garages, auto body shops, fabrication shops, and service trucks.
Advanced controls provide the adjustability professionals need, while PowerSet simplifies setup for beginners and experienced welders alike. It automatically selects key settings, reducing setup time and the need for charts or calculator apps. Voltage and amperage can be fine-tuned where applicable to suit welding position, technique, and personal preference. Its small stature saves shop space and makes it easy to take welding and cutting capability to the jobsite. In the shop or home garage, the multi-process design means a smaller footprint, which also means all you will need is one cart.
  1. Dual Voltage 120/240V Input for go anywhere capability
  2. Use with 4" or 8" wire spools for maximum utility
  3. Wire Jog for easy wire installation without running gas flow
  4. PowerSet synergic feature for easier setup and improved results with less operator input
  5. Use Plasma cutting feature with smaller 30 gallon 5.3 cfm compressors
  6. Spool Gun Capable with optional spool gun for distance Aluminum Welding
  2. 8,500 Surge Watts
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 35 A
240V 1 Phase 50/60Hz: 33 A
120V 1 Phase 50/60Hz: 21 A
240V 1 Phase 50/60Hz: 20 A
4.3 inches
Type
TFT
Resolution
HD 720
30 Programs
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 200A/24V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 200 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 24 Volts
74V
Auto or Off Seconds
Auto or Off Seconds
MIG Pulse
None
Spool Sizes
4”
8”
.030”
.035”
2
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Wire Feed Speed
120V: 400 IPM 240V: 600 IPM
Torch/Gun
24 Series 10 Ft.
24 gauge to 5/16"
20 gauge to 5/16"
1/8"- 1/4"
1/16"- 5/32"
Recommended Manual Hand Plasma Cutting Thickness:
  1. Up to 3/8" daily use
  2. Up to 1/2" clean cut
  3. Up to 5/8" severance cut
  4. Pierce up to 3/8"
  1. NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
Downloads
