Thunder 215 MTS, view 1
Thunder 215 MTS, view 2
Thunder 215 MTS, view 3
Thunder 215 MTS, view 4
Thunder 215 MTS, view 5
Thunder 215 MTS, view 6
Thunder 215 MTS, view 7
SKU# THUN-215-DV
Thunder 215 MTS
MIG
$1,529.00
$1,250.00
Save - $279.00
Thunder 215 MTS
MIG
SKU# THUN-215-DV
  • Unit Weight: 57 lb
  • Unit Dimensions: 9.25 in × 27.5 in × 15 in
Thunder 215 MTS
The Everlast Thunder 215 MTS packs professional MIG, DC TIG and Stick capability into a compact welder ready for shop fabrication, garage projects and portable repairs. With up to 215A of MIG and TIG output, a 35% duty cycle at 200A and a 5-year warranty, it delivers serious versatility at a competitive price.
Setup is straightforward on the bright 4.3" full-color LCD. Each process displays its settings on one screen, with clear navigation and reminders for polarity, voltage and shielding gas. Save, name and lock your custom programs for repeat jobs, or use Synergic PowerSet to get starting settings from basic material and wire information, then fine-tune the arc with an on-screen visual guide.
MIG controls include adjustable inductance, burnback, pre- and post-flow, and spot/stitch timers to help dial in starts, arc response and weld finish. DC TIG adds high-frequency or lift starting, a built-in gas solenoid, an included foot pedal, 2T/4T operation and adjustable pulse up to 150 Hz. Pulse is available in TIG mode only; this model does not offer pulse MIG.
For Stick welding, adjustable hot start and arc force help tailor the arc, while anti-stick makes stuck electrodes easier to release. VRD reduces open-circuit voltage when required, and a dedicated E6010 setting supports cellulosic electrodes.
From quick repairs to more demanding fabrication, the Thunder 215 MTS gives you the controls to tackle a wide range of work without filling your shop with separate machines.
  1. Dual 120/240V input for maximum go-anywhere usability
  2. Supports both Spool Gun and Push Pull Gun operation for Aluminum
  3. MIG, DC Pulse TIG and Stick for ability to weld almost anything (DC TIG does not weld aluminum)
  4. Compact size and weight allow the unit to be carried almost anywhere with little effort
  5. Holds 8" and 4" spools of wire (10-12 lbs. and 2 lbs.)
  6. Separate MIG and TIG gas connections
  2. 9,500 Surge Watts
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 33 A
240V 1 Phase 50/60Hz: 37 A
120V 1 Phase 50/60Hz: 20 A
240V 1 Phase 50/60Hz: 23 A
4.3 inches
Type
TFT
Resolution
720
30 Programs
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 215A/24.8V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 210 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 24.8 Volts
85V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-15 Seconds
0-20 Seconds
0-5 Seconds
0-5 Seconds
MIG Pulse
None
Spool Sizes
4”
8”
.030”
.035”
2
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Spot
Stitch
Wire Feed Speed
120V: 425 IPM 240V: 600 IPM
Torch/Gun
North 24 Series
24 gauge to 5/16"
20 gauge to 5/16"
1/8"- 5/16""
.015" to 5/16"
.015" to 5/16"
Not for use with Aluminum. Unit is DC only.
1/16"- 5/32"
Downloads
