Typhoon 330 480V 3Ph  375LF Cart, W375 Cooler, and Wireless Pedal Bundle Package, view 1
Typhoon 330 480V 3Ph  375LF Cart, W375 Cooler, and Wireless Pedal Bundle Package, view 2
Typhoon 330 480V 3Ph  375LF Cart, W375 Cooler, and Wireless Pedal Bundle Package, view 3
Typhoon 330 480V 3Ph  375LF Cart, W375 Cooler, and Wireless Pedal Bundle Package, view 4
PowerCool 375 Front
PowerCool 375 Front
SKU# TYP-330-480-375LF-W375-NVAFT06-Bundle-T
Digital AC/DC
$5,776.00
$4,199.00
Save - $1,577.00
Digital AC/DC
  • Unit Weight: 62 lb
  • Unit Dimensions: 9.5 in × 26 in × 15 in
This Typhoon 330 480V 3 phase bundle package includes the PowerCart 375LF and the PowerCool 375 water cooler and NOVA wireless foot pedal. This complete package gives you everything that normally comes with the Typhoon 330 (480V 3 phase version) including the standard accessory package. The cooler included in this package stacks securely under the Typhoon 330 480V 3 phase with a smooth, connected look. The cart is designed to hold both the welder and cooler. If the cooler isn't needed, it can hold just the welder as well. Adjustable tabs on the cart keep the welder and cooler from sliding around. The NOVA wireless foot pedal is also included and will plug into the rear of the unit for power. The foot pedal is good for up to 300 ft away and can be used with other NOVA pedals in the same area with no cross-talk. This professional package is perfect for small shops and fabrication facilities that need a compact water-cooled package. Be sure to add a cover after selecting this package under the "add accessories" option to keep the welder protected when not in use.
Includes:
  1. Typhoon 330 480V
  2. Typhoon 330 480V 3 phase accessory package
  3. NOVA PowerCart 375LF
  4. PowerCool W375 Water Cooler
  5. NOVA Wireless TIG Foot Pedal
  2. 15,500 Surge Watts
  1. Unit is equipped with separate water cooler and wire less foot pedal power outlets.
  2. Do not plug any other device into the water cooler outlet or into the outlet intended for powering the wireless foot pedal.
480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 18 A
480V 3 Phase 50/60Hz: 12 A
5.1 inches
Type
TFT
Resolution
720
21S
30 Programs
Temperature Controlled
On-Arc
TIG Duty Cycle 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 330A/23.2V Rated Output
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 270A/20.8V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 210A/18.4V Rated Output
TIG Output Range 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz TIG Amp AC Output Range: 3 to 330 Amps
480V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.1 to 23.2 Volts
480V 3 Phase 50/60Hz TIG Amp DC Output Range: 2 to 330 Amps
480V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 23.2 Volts
83V
TIG Start Type
Live Lift Start
Lift Start With Remote
Start Amp Range AC
3-330A
Start Amp Range DC
2-330A
End Amp Range AC
3-330A
End Amp Range DC
2-300A
0-30 Seconds
0-60 Seconds
0-30 Seconds
0-60 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
Triangular
Trapezoid
Sine
Double
DC Pulse Frequency
0-0-999 Hz
DC Double Pulse Frequency
0-9.9 Hz
AC Pulse Frequency
0-500 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
3-100% of Welding Amperage
AC Frequency
20-400 Hz
AC Balance
5-70% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Trapezoid
Sine
Other Functions
Fast Tack (Cold Weld Function) Spot and Stitch Timer
.003" to 1/2"
.003" to 1/2"
.005"- 7/16"
1/16"- 1/4"
  • Aerospace
  • Rail Car Industry
  • Pipe and Structural
  • Gunsmithing
