Cyclone 262i with SN-24 MIG Gun
SKU# CLN-262i-24
- Unit Weight: 69 lb
- Shipping Weight: 81 lb
Compact and powerful, the Cyclone 262i delivers professional MIG, Stick and basic DC lift Start TIG performance for industrial fabrication while fitting comfortably in home garages and shops of any size. Its bright 4.3" TFT color display provides large, easy-to-read output settings, and a 50% MIG duty cycle at 275A helps keep work moving with fewer cool down interruptions.
Advanced MIG controls include automatic run-in, adjustable start and end wire feed speeds, crater filling, wire feed slope control for 2T/4T operation, adjustable inductance, Spot and Stitch timers, and pre- and post-flow gas control. For Stick welding, the Cyclone handles a broad range of electrodes, including E6010. Adjustable Arc Force, Hot Start, and Hot Start duration let you tailor performance to the electrode and welding position.
Setup is straightforward with intuitive controls and PowerSet, which automatically selects settings based on basic inputs such as wire size and material thickness. Available in both MIG and Stick modes, PowerSet helps beginners and professionals set up quickly. Multiple program memories let you save preferred settings for consistent, repeatable results.
The unit comes configured for .035" and .045" wire, with optional components available for sizes from .023" to .062".
- 240V input
- 4.3" HD TFT screen
- Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls
- Additional polymer liner, U-Groove drive roll and Spool Gun are optional
- 13500 Surge Watts
- This welder ships with a 24 series MIG gun configured for heavy commercial spray arc welding. It comes with a yellow liner for .045–.062" wire installed. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A red liner (.040–.045") is available for .045" wire, and a blue liner is available for .035" and smaller wire. Purchase additional liners to match the wire sizes you plan to use.
- For welding below 230 amps or for short-circuit applications, 24 series MIG gun is especially a good choice since it comes with a red .040"–.045" liner. Liners are interchangeable.
- Do not use .030" or smaller wire in a MIG gun longer than 15 ft.
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 52 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 37 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 50% Duty Cycle @ 40°C at 275A/27.8V Rated Output
| Up-Slope Time | 0-1 Seconds
2T SP
4T SP
| MIG Pulse | None
| Spool Sizes | 8”
12”
Steel V-groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
| Other MIG Functions | Spot
Stitch
| Wire Feed Speed | 600 IPM
| Torch/Gun | SN-24 MIG Gun 10 ft. (North)
| Important MIG Specification Notes | Purchase a separate liner for each wire size that will be used
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 50% Duty Cycle @ 40°C at 230A/29.2V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 230 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 29.4 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 50% Duty Cycle @ 40°C at 275A/21V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 230 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 21 Volts
24 gauge to 3/8"
22 gauge to 3/8"
1/8-3/8"
1/16"- 3/16"
.015" to 3/8"
.015" to 3/8"
- Aerospace
