Cyclone 263Pi & Parker DSP 360 Spool Gun (Bundle)
SKU# CLN-263PI-DSP360-BUNDLE
- Unit Weight: 70 lb
- Unit Dimensions: 11.25 in × 28 in × 18 in
The Cyclone 263Pi is built for professionals who need the speed and productivity of a single Pulse MIG without giving up the control, versatility, and durability expected from a serious commercial welding machine. Its digitally controlled synergic technology and refined programming help simplify setup while delivering smooth, consistent arc performance across a wide range of applications.
With 275A of MIG output at a 60% duty cycle, the Cyclone 263Pi is designed for demanding fabrication, structural work, repair, and production environments. Dedicated settings for steel, stainless steel, aluminum, gas-shielded flux-cored, and gasless flux-cored wire give the operator the flexibility to move from one job to the next without changing machines. Fully synergic Pulse MIG provides excellent control over heat input and arc behavior while dramatically reducing spatter, helping produce clean, high-quality welds with less time spent on cleanup.
For aluminum work, the Cyclone 263Pi is ready for both optional spool guns and push-pull guns, making it well suited for applications where additional reach or more reliable aluminum wire feeding is needed.
And while single Pulse MIG capability may be one of its biggest strengths, the Cyclone 263Pi is far from a one-process machine. It performs equally well in conventional short-circuit and spray-arc MIG applications and comes equipped with a heavy-duty MIG gun designed to handle the heat and duty cycle the machine can deliver.
The Cyclone 263Pi also adds capable Stick and DC TIG performance for the jobs that call for something different. Its Stick mode supports E6010 and most common electrodes up to 5/32", with some electrode types supported up to 3/16". Basic, no frills Lift Start DC TIG rounds out the package for applications such as pipe work, construction, maintenance, and commercial steel fabrication where you need a "TIG-rig", pedal-less style of operation.
For the professional who wants one machine that can handle production work, structural fabrication, aluminum, field repair, and general shop use, the Cyclone 263Pi delivers a practical combination of power, control, and everyday versatility.
- 240V input
- 5.1" HD TFT screen
- Single Pulse Synergic MIG with multiple wire/metal type selection for optimized performance
- Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls
- Additional polymer liner, U-Groove drive roll and Spool Gun are optional
- 13500 Surge Watts
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 48 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 38 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720 HD
| Memory | 30 Programs
2T SP
4T SP
| MIG Pulse | Single
| MIG Pulse Pinch Effect | No
| Spool Sizes | 8”
12”
| Wire Feeder Type | Internal/Self Contained Wire Feeder
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
| Wire Feed Speed | 600 IPM
| Torch/Gun | 36 Series 10 Ft.
| Important MIG Specification Notes | This unit is Single Pulse only. It is not Double Pulse.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 230A/29.2V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 230 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 29.2 Volts
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 20 Volts
| Important TIG Specification Notes | This is a basic DC Lift TIG. There is no pedal control, or remote amperage set. It is not designed to weld aluminum. Recommend a 17V gas valve torch for TIG RIG setup.
24 gauge to 1/2"
22 gauge to 1/2"
.045-7/16"
1/16"- 3/16"
.020" to 3/8"
.020" to 3/8"
- Aerospace
- 36 Series MIG Gun 3m 10 ft.
- Drive Roll Flux Core Double (Flux-Core Wire) – .045"-.062" (1.2-1.6mm)
- Drive Roll V-Groove Double (Steel/Stainless) – .023"-.030" (0.6-0.8mm)
- 6.5 Ft. Power Cord with NEMA 6-50 Plug
- Contact Tip M8 Thread
- Parker DSP 360 Spool Gun (promo)
