Cyclone 263Pi Single Pulse MIG with 375LF Cart and North 300 MPG Push-Pull Gun Package, view 1
Cyclone 263Pi Single Pulse MIG with 375LF Cart and North 300 MPG Push-Pull Gun Package, view 2
Cyclone 263Pi Single Pulse MIG with 375LF Cart and North 300 MPG Push-Pull Gun Package, view 3
Cyclone 263Pi Single Pulse MIG with 375LF Cart and North 300 MPG Push-Pull Gun Package, view 4
Cyclone 263Pi Single Pulse MIG with 375LF Cart and North 300 MPG Push-Pull Gun Package, view 5
SKU# CLN-263Pi-375LF-MPG 300
Pulse MIG
$4,327.00
$3,847.00
Save - $480.00
Pulse MIG
  • Unit Weight: 70 lb
  • Unit Dimensions: 11.25 in × 28 in × 18 in
The Cyclone 263Pi North MPG 300 Push-Pull Gun package includes everything in the Cyclone 263Pi welder package plus the heavy-duty North 300 MPG air-cooled push-pull gun with 25 Ft. cable. This package works well for all types of aluminum welding. This package also includes the NOVA PowerCart 375LF welding cart.
Includes:
  1. Cyclone 263Pi MIG/Stick/DC Lift TIG welder
  2. Cyclone 263Pi standard accessory kit
  3. North MPG 300 Push-Gun 25 Ft.
  4. NOVA PowerCart 375LF
  2. 13500 Surge Watts
240V 1 Phase 50/60Hz: 48 A
240V 1 Phase 50/60Hz: 38 A
5.1 inches
Type
TFT
Resolution
720 HD
21S
30 Programs
80V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
MIG Hot Start Duration
Adjustable
MIG Crater Fill (End Fill)
Adjustable
Adjustable
0-10 Seconds
0-30 Seconds
0-1.0 Seconds
0-1.0 Seconds
2T SP
4T SP
MIG Pulse
Single
MIG Pulse Pinch Effect
MIG Pulse Operation
Synergic
Spool Sizes
8”
12”
Wire Feeder Type
Internal/Self Contained Wire Feeder
.035”
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
Wire Feed Speed
600 IPM
Torch/Gun
36 Series 10 Ft.
This unit is Single Pulse only. It is not Double Pulse.
24 gauge to 1/2"
22 gauge to 1/2"
.045-7/16"
1/16"- 3/16"
.020" to 3/8"
.020" to 3/8"
  • Aerospace
