Cyclone 273DPi & North MPG 300 Push Pull Gun (Bundle), view 1
Cyclone 273DPi & North MPG 300 Push Pull Gun (Bundle), view 2
Cyclone 273DPi & North MPG 300 Push Pull Gun (Bundle), view 3
Cyclone 273DPi & North MPG 300 Push Pull Gun (Bundle), view 4
Cyclone 273DPi & North MPG 300 Push Pull Gun (Bundle), view 5
Cyclone 273DPi & North MPG 300 Push Pull Gun (Bundle), view 6
SKU# CLN-273DPI-MPG300-BUNDLE-13
Pulse MIG
$4,550.00
$4,000.00
Save - $550.00
Pulse MIG
  • Unit Weight: 70 lb
  • Unit Dimensions: 11.25 in × 28 in × 18 in
The Everlast Cyclone 273DPi combines the precision of advanced Single and Double Pulse MIG technology with the speed and productivity of conventional MIG welding. Designed for professional fabrication, production, and repair, it delivers exceptional versatility across a wide range of material thicknesses, from thin sheet metal requiring precise heat control to heavier plate and structural applications demanding greater penetration.
The advanced Synergic Single and Double Pulse MIG system produces exceptionally smooth, clean welds with a uniform, bead appearance. Single pulse offers great control over heat and warping. When using Double Pulse, not only is there heat control, but in many applications, the finished weld is difficult to distinguish from TIG, making Double Pulse MIG a practical alternative when appearance, speed, and productivity matter. With significantly faster travel speeds than traditional TIG welding, the Cyclone 273DPi helps reduce production time without sacrificing weld quality.
Precise control over heat input and the weld puddle helps minimize distortion and burn-through on thinner materials while maintaining excellent performance on heavier sections. The pulse process also produces little to no spatter, virtually eliminating much of the grinding and post-weld cleanup associated with conventional MIG welding. The result is faster production, less finishing work, and greater overall efficiency.
When Double Pulse isn't needed, the Cyclone 273DPi offers Single Pulse MIG, conventional short-circuit, and spray arc MIG welding, allowing operators to match the process to the application. Whether welding steel, stainless steel, or aluminum, the intuitive synergic controls simplify setup and adjustment, making advanced pulse welding accessible without complicated programming.
From thin sheet metal to heavy fabrication, the Cyclone 273DPi delivers TIG-like weld appearance, professional-grade performance, and the production speed to improve your bottom line. With exceptional versatility, virtually spatter-free welding, and significantly reduced cleanup, it's a practical solution for shops looking to produce better-looking welds in less time.
  1. 240V 1 or 3 phase input
  2. 5.1" HD TFT screen
  3. Single and Double Pulse Synergic MIG with multiple wire/metal type selection for optimized performance
  4. PowerSet mode for easy setup and reduced input
  5. Wire Jog and Gas Purge for easier wire installation and changeover
  6. Basic DC Lift TIG function with optional gas valve TIG torch (TIG rig)
  7. Additional Stick welding function for welding with cellulosic (E6010), iron powder and titania rods
  8. The advanced PowerSet function reduces time and effort to set up the welder and yields satisfactory results
  9. The adjustable settings in PowerSet mode allow for plenty of adjustment to allow for different welding positions
  10. 12" and 8" wire spool capacity (10-12lbs. and 30-44lbs.)
  11. Weld and Braze with MIG
  12. Can use spool gun or stock gun with polymer liner for Aluminum with U-groove drive rolls
  13. Includes 2 guns, liners, and drive rolls for steel and aluminum welding
  2. 13,500 Surge Watts recommended
  1. This welder ships with two 24 series MIG gun configured for a variety of welding needs. Heavy, sustained maximum amp welding may require a 36 series gun to be purchased. It comes with a red steel and a red polymer (for aluminum) liner for .040 and .045" wire installed. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A blue liner (.030–.035") is available for smaller wire. So, be sure to purchase additional liners to match the wire sizes you plan to use. In most cases .047" (aluminum) wire will be the best choice for all gauges of aluminum, thick or thin.
  2. Do not use .030" or smaller steel/stainless wire in a MIG gun longer than 12 feet. Do not feed aluminum wire smaller than .047"/ 3/64" / 1.2mm through standard gun. Always use polymer liner for feeding aluminum. This may require a liner change. 4043 may not feed well through main gun. Use 4943 instead. It is the preferred 40XX series for replacing 4043 wire.
  3. Gasless Flux-cored operation is limited with the standard gun and is only able to be used for short periods of time with the standard gun that comes with the unit. Performance may be marginal as well and damage to the gun may result. There are no conversion kits for this gun. A dedicated Flux-Cored gun should be used if it is to be used regularly with gasless flux-cored wire.
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 53 A
240V 3 Phase 50/60Hz: 26 A
240V 1 Phase 50/60Hz: 41 A
240V 3 Phase 50/60Hz: 21 A
5.1 inches
Type
TFT
Resolution
720 HD
21S
30 Programs
MIG Duty Cycle 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 275A/27.8V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/24V Rated Output
MIG Output Range 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz MIG Amp DC Output Range: 30 to 275 Amps
240V 3 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 27.8 Volts
75V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
MIG Hot Start Duration
Adjustable
MIG Crater Fill (End Fill)
Adjustable
Adjustable
0-10 Seconds
0-30 Seconds
0-1.0 Seconds
0-1.0 Seconds
2T SP
4T SP
MIG Pulse
Single and Double
MIG Pulse Pinch Effect
MIG Pulse Operation
Synergic
Spool Sizes
8”
12”
Wire Feeder Type
Internal/Self Contained Wire Feeder
.035”
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
Wire Feed Speed
600 IPM
Torch/Gun
24 Series 10 Ft. x 2
This unit is Single Pulse and Double Pulse.
24 gauge to 3/8"
22 gauge to 3/8"
.045-3/8"
1/16"- 3/16"
.020" to 3/8"
.020" to 3/8"
  • Aerospace
Downloads
