Cyclone 273DPi & Parker SGP 360 Push Pull Gun (Bundle)
SKU# CLN-273DPI-SGP360-BUNDLE-13
- Unit Weight: 70 lb
- Unit Dimensions: 11.25 in × 28 in × 18 in
The Cyclone 273DPi Parker SGP 360 Push-Pull Gun package includes everything in the Cyclone 273DPi welder accessory package plus the heavy-duty Parker SGP a 273DPi air-cooled push-pull gun with 24 Ft. cable. This package works well for all types of aluminum welding.
Includes:
- Cyclone 263Pi MIG/Stick/DC Lift TIG welder
- Cyclone 263Pi standard accessory kit
- Parker Push-Pull SGP 360A 24 Ft.
- 13,500 Surge Watts recommended
- This welder ships with two 24 series MIG gun configured for a variety of welding needs. Heavy, sustained maximum amp welding may require a 36 series gun to be purchased. It comes with a red steel and a red polymer (for aluminum) liner for .040 and .045" wire installed. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A blue liner (.030–.035") is available for smaller wire. So, be sure to purchase additional liners to match the wire sizes you plan to use. In most cases .047" (aluminum) wire will be the best choice for all gauges of aluminum, thick or thin.
- Do not use .030" or smaller steel/stainless wire in a MIG gun longer than 12 feet. Do not feed aluminum wire smaller than .047"/ 3/64" / 1.2mm through standard gun. Always use polymer liner for feeding aluminum. This may require a liner change. 4043 may not feed well through main gun. Use 4943 instead. It is the preferred 40XX series for replacing 4043 wire.
240V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 53 A
240V 3 Phase 50/60Hz: 26 A
240V 3 Phase 50/60Hz: 21 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720 HD
| Memory | 30 Programs
| MIG Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 275A/27.8V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/24V Rated Output
| MIG Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz MIG Amp DC Output Range: 30 to 275 Amps
240V 3 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 27.8 Volts
| Open Circuit Voltage (OCV) | 75V
2T SP
4T SP
| MIG Pulse | Single and Double
| Spool Sizes | 8”
12”
| Wire Feeder Type | Internal/Self Contained Wire Feeder
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
| Wire Feed Speed | 600 IPM
| Torch/Gun | 24 Series 10 Ft. x 2 plus Parker SGP 360 Push-Pull
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/28V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 160A/26.4V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 200 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28 Volts
| Stick Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz Stick Amp DC Output Range: 10 to 200 Amps
240V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28 Volts
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
24 gauge to 3/8"
22 gauge to 3/8"
.045-3/8"
1/16"- 3/16"
.020" to 3/8"
.020" to 3/8"
- Aerospace
- Parker SGP 360A Air-Cooled Push-Pull Gun (7 Pin) 25 Ft. Euro Quick Connect
- Contact Tips M6 Thread .035" and .045"
- Parker SGP 360 Push Pull Gun
