Cyclone 312i PRO & North MPG 300 Push Pull Gun (Bundle), view 1
Cyclone 312i PRO & North MPG 300 Push Pull Gun (Bundle), view 2
Cyclone 312i PRO & North MPG 300 Push Pull Gun (Bundle), view 3
SKU# CLN-312I-PRO-MPG300-BUNDLE
MIG
$4,280.00
$3,900.00
Save - $380.00
MIG
  • Shipping Weight: 163 lb
  • Unit Dimensions: 11.25 in × 33.5 in × 25 in
The Everlast Cyclone 312i Pro is a professional, heavy-duty MIG/Stick welder ready for almost any work environment. It delivers up to 315A of MIG power and 250A of Stick power, with a 35% duty cycle at maximum output. Its integrated undercarriage makes it easy to roll around shops or jobsites with hard surfaces. The cart system includes a protective roll bar surrounding the cabinet and a rear gas cylinder carrier to keep your welding setup together.
A bright 4.3" color display keeps settings easy to read. PowerSet simplifies setup with recommended voltage and wire speed settings based on your gas, wire type, and wire size, with fine-tuning available for specific applications. Adjustable gas flow, inductance, and burnback help refine MIG performance, while 2T/4T controls and spot and stitch timers support long seams and consistent welds. Stick mode handles electrodes including E6010 and offers PowerSet settings for a variety of steel rods. Memory storage saves your preferred settings for both processes.
  1. The Cyclone 312i Pro model includes cart system which includes roll over bars with rear cylinder carrier
  2. 240V input
  3. 4.3" HD TFT screen
  4. PowerSet mode for easy setup and reduced input
  5. Wire Jog and Gas Purge for easier wire installation and changeover
  6. Basic DC Lift TIG function with optional gas valve TIG torch (TIG rig)
  7. Additional Stick welding function for welding with cellulosic (E6010), iron powder and titania rods
  8. The advanced PowerSet function reduces time and effort to set up the welder and yields satisfactory results
  9. The adjustable settings in PowerSet mode allow for plenty of adjustment to allow for different welding positions
  10. 12" and 8" wire spool capacity (10-12lbs. and 30-44lbs.)
  11. Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls
  12. Additional polymer liner, U-groove drive roll and Spool Gun are optional
  2. 16500 Surge Watts
  1. This welder ships with a 36 series MIG gun configured for heavy commercial spray arc welding. It comes with a yellow liner for .045"–.062" wire installed. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A red liner (.040"–.045") is available for .045" wire, and a blue liner is available for .035" and smaller wire. Purchase additional liners to match the wire sizes you plan to use.
  2. For welding below 230 amps or for short-circuit applications, purchase the optional 24 series MIG gun, which comes with a red (.040"–.045") liner. Liners are interchangeable between the two guns, provided they are the same length.
  3. Do not use .030" or smaller wire in a MIG gun longer than 15 ft.
  4. Gasless Flux-Cored operation is limited with the standard gun and is only able to be used for short periods of time with the standard gun that comes with the unit. Performance may be marginal as well and damage to the gun may result. There are no conversion kits for this gun. A dedicated Flux-Cored gun should be used if it is to be used regularly with gasless flux-cored wire.
240V 1 Phase 50/60Hz: 64 A
240V 1 Phase 50/60Hz: 41 A
5.1 inches
Type
TFT
Resolution
HD 720
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/29.8V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 315 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 24 Volts
70V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-10 Seconds
0-30 Seconds
0-1 Seconds
0-1 Seconds
2T SP
4T SP
MIG Pulse
None
Spool Sizes
8”
12”
.035”
Steel V-groove
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Run-In
Other MIG Functions
Spot, Stitch, Undercarriage
Wire Feed Speed
600IPM
Torch/Gun
36 Series 10 Ft. (North)
Purchase a separate liner for each wire size that will be used. For under 230A operation, purchase a 24 series gun. This model includes a cart system (undercarriage) with a cylinder rack in the rear.
24 gauge to 1/2"
22 gauge to 1/2"
1/8-3/8"
1/16"- 3/16"
.015" to 1/2"
.015" to 1/2"
  • Aerospace
Downloads
