Cyclone 312i PRO & Parker DSP 360 Spool Gun (Bundle)
SKU# CLN-312I-PRO-DSP360-BUNDLE
- Shipping Weight: 163 lb
- Unit Dimensions: 11.25 in × 33.5 in × 25 in
The Everlast Cyclone 312i Pro is a professional, heavy-duty MIG/Stick welder ready for almost any work environment. It delivers up to 315A of MIG power and 250A of Stick power, with a 35% duty cycle at maximum output. Its integrated undercarriage makes it easy to roll around shops or jobsites with hard surfaces. The cart system includes a protective roll bar surrounding the cabinet and a rear gas cylinder carrier to keep your welding setup together.
A bright 4.3" color display keeps settings easy to read. PowerSet simplifies setup with recommended voltage and wire speed settings based on your gas, wire type, and wire size, with fine-tuning available for specific applications. Adjustable gas flow, inductance, and burnback help refine MIG performance, while 2T/4T controls and spot and stitch timers support long seams and consistent welds. Stick mode handles electrodes including E6010 and offers PowerSet settings for a variety of steel rods. Memory storage saves your preferred settings for both processes.
- The Cyclone 312i Pro model includes cart system which includes roll over bars with rear cylinder carrier
- 240V input
- 4.3" HD TFT screen
- Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls
- Additional polymer liner, U-groove drive roll and Spool Gun are optional
- 16500 Surge Watts
- This welder ships with a 36 series MIG gun configured for heavy commercial spray arc welding. It comes with a yellow liner for .045"–.062" wire installed. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A red liner (.040"–.045") is available for .045" wire, and a blue liner is available for .035" and smaller wire. Purchase additional liners to match the wire sizes you plan to use.
- For welding below 230 amps or for short-circuit applications, purchase the optional 24 series MIG gun, which comes with a red (.040"–.045") liner. Liners are interchangeable between the two guns, provided they are the same length.
- Do not use .030" or smaller wire in a MIG gun longer than 15 ft.
- Gasless Flux-Cored operation is limited with the standard gun and is only able to be used for short periods of time with the standard gun that comes with the unit. Performance may be marginal as well and damage to the gun may result. There are no conversion kits for this gun. A dedicated Flux-Cored gun should be used if it is to be used regularly with gasless flux-cored wire.
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 64 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/29.8V Rated Output
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 24 Volts
| Up-Slope Time | 0-1 Seconds
2T SP
4T SP
| MIG Pulse | None
| Spool Sizes | 8”
12”
Steel V-groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
| Other MIG Functions | Spot,
Stitch,
Undercarriage
| Wire Feed Speed | 600IPM
| Torch/Gun | 36 Series 10 Ft. (North)
| Important MIG Specification Notes | Purchase a separate liner for each wire size that will be used. For under 230A operation, purchase a 24 series gun.
This model includes a cart system (undercarriage) with a cylinder rack in the rear.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 250A/30V Rated Output
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/22.6V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 22.6 Volts
24 gauge to 1/2"
22 gauge to 1/2"
1/8-3/8"
1/16"- 3/16"
.015" to 1/2"
.015" to 1/2"
- Aerospace
- Parker DSP 360A Spool Gun 25 Ft. Euro Quick Connect
- Parker DSP 360 Spool Gun (promo)
