Drive Roll U-Groove Single (Aluminum and Bronze)
$20.00
SKU# EV-DR-UG-0809
This bottom-mounted U-groove drive roll for Aluminum and Bronze wires fits multiple Everlast MIG welders equipped with a two-roll wire feed system. In this configuration, the lower drive roll feeds the wire, while the upper roll is typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only one U-grooved drive roll is required. Select the appropriate drive roll for the type and diameter of wire you are using.
Keep in Mind:
- This is a .030"-.035" drive roll which may have markings of 0.8mm-0.9mm equivalent groove sizes.
- It is U-Groove for Aluminum and Bronze solid wire feeding use.
Special Note:
- .030" wire needs high wire speed to weld Aluminum. Use only with Everlast welders rated for 600 IPM or greater and in MIG guns with blue teflon liners 10 ft. long or less.
