Drive Roll U-Groove Single (Aluminum and Bronze)
SKU# EV-DR-UG-1012
This bottom-mounted U-groove drive roll for Aluminum and Bronze wires fits multiple Everlast MIG welders equipped with a two-roll wire feed system. In this configuration, the lower drive roll feeds the wire, while the upper roll is typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only one U-grooved drive roll is required. Select the appropriate drive roll for the type and diameter of wire you are using.
Keep in Mind:
  1. This is a .040"-.045" drive roll which may have markings of 1.0mm-1.2mm equivalent groove sizes.
  2. It is U-Groove for Aluminum and Bronze solid wire feeding use.
  4. .047" is nominally the same as .045" and 3/64" wire as well as 1.2mm. These sizes are interchangeable and no difference in wire feeding will occur.
