Drive Roll U-Groove Single (Aluminum and Bronze)
$20.00
SKU# EV-DR-UG-0910
This bottom-mounted U-groove drive roll for Aluminum and Bronze wires fits multiple Everlast MIG welders equipped with a two-roll wire feed system. In this configuration, the lower drive roll feeds the wire, while the upper roll is typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only one U-grooved drive roll is required. Select the appropriate drive roll for the type and diameter of wire you are using.
Keep in Mind:
- This is a .035"-.040" drive roll which may have markings of 0.9-1.0mm equivalent groove sizes.
- It is U-Groove for Aluminum and Bronze solid wire feeding use.
Special Note:
- .040" wire is a specialized type of wire size. It is used commonly in the auto-body industry and is usually listed as 1.0mm. To use both .030" and .040" grooves, you may need to change between the blue and the red polymer/teflon gun liner when the wire diameter is changed.
