PowerPlasma 52i
SKU# PP-52I
- Unit Weight: 32 lb
- Shipping Weight: 38 lb
- Unit Dimensions: 7 in × 16 in × 13 in
The PowerPlasma 52i is a good choice for professionals needing a compact, but powerful plasma cutter. The dual voltage 120/240V input and compact size and moderate input amp requirement makes the unit ideal for portable welding and cutting operations.
- Dual Voltage 120/240V
- CNC Port Built IN
- Blow-Back Style Pilot Arc iPT 60 Hand Cutting Torch
- Parts in Place safety cut out
- Low air pressure safety cut out
- Gouge (light gouging) function
Generator Requirements*:
- 8500 Surge Watts
Important Note:
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 30 A
240V 1 Phase 50/60Hz: 33 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 24 A
240V 1 Phase 50/60Hz: 26 A
| LCD Screen | No
| Memory | No
| Plasma Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 25A/90V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 20A/88V Rated Output
| Plasma Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 50A/100V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 40A/96V Rated Output
| Open Circuit Voltage (OCV) | 280V
| Torch Type | iPT 60 Hand Torch
| CNC Capable/Ready | Yes, with optional Torch
| Gouging Duties | Light
| Recommended Flow Rate (Air) | 5.3 CFH @ 90 PSI
| Compressor Built In | No
| Remote | 2T
| Tip Saver Function | Yes
| Location of CNC Port | Rear
- Up to 3/8-1/2" daily use
- Up to 3/4" clean cut
- Up to 1" severance cut
- Pierce up to 5/16-3/8"
Units are supplied with a starter set of consumables intended primarily for cutting in the 40–50 amp range. While there is effectively no practical minimum material thickness that can be cut, standard higher-amperage tips may produce an unnecessarily wide kerf on very thin material. For best results on lighter gauges, use a consumable with a smaller orifice matched to the required cutting amperage.
- Up to 5/16" daily use
- Up to 1/2" clean cut (edge start)
- Pierce up to 5/16"
- Aerospace
- Pipe and Structural
- iPT-60 Hand Plasma Torch Blow Back Start 14 Ft. Central Connector
- WEiPu SP21 CNC Connector 12 Pin
- Starter Consumable Kit (5) IPT-60 Electrodes, (5) IPT 60 1.1 mm (50A) Cutting Tips
- 240-120V Pig Tail Adapter
