PowerPlasma 52i CNC Package
SKU# PP-52I-CNC
- Unit Weight: 32 lb
- Shipping Weight: 42 lb
- Unit Dimensions: 16 in × 7 in × 13 in
This is the CNC version of the hand cutting 52i. In this version, the hand torch is replaced by the CNC torch. This unit is perfect for small cnc tables or track torches with sheet metal and light gauge plate metal 1/4" and under. 120V operation with CNC is not recommended.
- Dual Voltage 120/240V
- CNC Port built in
- Blow-Back Style Pilot Arc PTM-60 (Machine Torch)
- Parts in Place safety cut out
- Low air pressure safety cut out
Generator Requirements*:
- 8500 Surge Watts
Important Note:
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 30 A
240V 1 Phase 50/60Hz: 33 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 24 A
240V 1 Phase 50/60Hz: 26 A
| LCD Screen | No
| Memory | No
| Plasma Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 25A/90V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 20A/88V Rated Output
| Plasma Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 50A/100V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 40A/96V Rated Output
| Open Circuit Voltage (OCV) | 280V
| Torch Type | PTM 60 Machine Torch
| CNC Capable/Ready | Yes, included
| Gouging Duties | Light
| Recommended Flow Rate (Air) | 5.3 CFH @ 90 PSI
| Compressor Built In | No
| Remote | 2T
| Tip Saver Function | Yes
| Location of CNC Port | Rear
- Up to 3/8-1/2" daily use
- Up to 3/4" clean cut
- Up to 1" severance cut
- Pierce up to 5/16-3/8"
Units are supplied with a starter set of consumables intended primarily for cutting in the 40–50 amp range. While there is effectively no practical minimum material thickness that can be cut, standard higher-amperage tips may produce an unnecessarily wide kerf on very thin material. For best results on lighter gauges, use a consumable with a smaller orifice matched to the required cutting amperage.
- Up to 5/16" daily use
- Up to 1/2" clean cut (edge start)
- Pierce up to 5/16"
- Aerospace
- Pipe and Structural
- Plasma Table
- PTM-60 CNC/Machine Torch Blow Back Start 25 Ft. Central Connector
- Starter Consumable Kit: 5x IPT-60 Electrodes and 5x IPT-60 1.1mm Nozzles/Tips
