PowerPlasma 82i, view 1
PowerPlasma 82i, view 2
PowerPlasma 82i, view 3
PowerPlasma 82i, view 4
SKU# PP-82I
PowerPlasma 82i
Hand or CNC Cutting
$1,399.00
$1,269.00
Save - $130.00
PowerPlasma 82i
Hand or CNC Cutting
SKU# PP-82I
  • Unit Weight: 53 lb
  • Shipping Weight: 62 lb
PowerPlasma 82i
The PowerPlasma 82i is a professional plasma cutter ideal for any shop that needs serious cutting power with 240V 1 phase power. This unit features a heavy duty 80 amp hand cutting torch which works perfectly to cut up to and over 1" steel on a regular basis.
  1. 240V 1 phase input power
  2. CNC Port Built in
  3. Blow-Back Style, Pilot Arc Hand Cutting Torch
  7. Gouge function
Generator Requirements*:
  2. 14.000 Surge Watts
Important Note:
240V 1 Phase 50/60Hz: 55 A
240V 1 Phase 50/60Hz: 43 A
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/112V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 60A/104V Rated Output
300V
Arc Start Type
Blowback, Piston Type
Torch Type
iPT 80 Hand Torch
CNC Capable/Ready
Yes, with optional Torch
Gouging Capable
Gouging Duties
Medium
Heavy
Drag Cutting
Post Flow Timer
Adjustable
Parts-In-Place Safety Cut Out
Recommended Flow Rate (Air)
6.5 CFH @ 90 PSI
Maximum Supply Pressure
90 PSI
Compressor Built In
60 Gallon
65-75
Remote
Tip Saver Function
Location of CNC Port
Rear
CNC Port Type
WEiPu SP21 12 pin
Torch Connector Type
Central Euro
  1. Up to 1" daily use
  2. Up to 1 1/4" clean cut
  3. Up to 1 7/16" severance cut
  4. Pierce up to 5/8"
Units are supplied with a starter set of consumables intended primarily for cutting in the 70-80 amp range. While there is effectively no practical minimum material thickness that can be cut, standard higher-amperage tips may produce an unnecessarily wide kerf on very thin material. For best results on lighter gauges, use a consumable with a smaller orifice matched to the required cutting amperage.
  1. Up to 5/8" daily use
  2. Up to 1" clean cut (edge start)
  3. Pierce up to 1/2"
  • Aerospace
  • Pipe and Structural
