PowerPro 164Si
SKU# PP-164SI
- Unit Weight: 65 lb
- Shipping Weight: 92 lb
- Unit Dimensions: 9.75 in × 24 in × 15 in
The PowerPro 164Si is an AC/DC TIG/ DC Stick/Plasma multi-process machine that works well in small shops and home garages where space is a concern. The all-in-one design is easy and intuitive to operate with basic controls. As an AC/DC TIG welder, it works well for prototyping, light fabrication and general repair duties on materials up to 3/16" thick. The stick function also performs well with E7018 and E7014 rods for general purpose welding. The 40A plasma cutter is more than capable of cutting anything the unit can weld.
- AC/DC TIG for welding Steel, Stainless and Aluminum metal types
- Dual-Voltage Input allows the unit to go anywhere a weld or cut is needed
- Simple 1 or 25Hz Pulse on TIG if desired for improved bead appearance
- AC Frequency and Balance Controls for improved TIG control
- Stick function works well with iron powder and titania fluxed rods
- Plasma cutter designed for hand cutting can cut up to 1/2" with ease
- 6500 Surge Watts
- Not for use with E6010 and most cellulosic rods
- E6011 use is permissible but performance may be brand dependent
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 25.5 A
240V 1 Phase 50/60Hz: 24.8 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 23 A
240V 1 Phase 50/60Hz: 20 A
| LCD Screen | No
| Memory | No
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/15V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/13.2V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/16.4V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/15.2V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 100 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 14.0 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 100 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 14.0 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 160 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 16.4 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 160 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 16.4 Volts
| Open Circuit Voltage (OCV) | 85V
HF Start with Point Gap Start
| Start Amp Range AC | Fixed
| Start Amp Range DC | Fixed
| End Amp Range AC | Fixed
| End Amp Range DC | Fixed
| Pre-Flow Time | Fixed
| Post-Flow Time | 0-10 Seconds
| Up-Slope Time | Fixed
| TIG Pulse | AC
| AC Pulse Type | Standard
| DC Pulse Frequency | .1 or 25 Hz
| AC Pulse Frequency | .1 or 25 Hz
| Pulse Time-On (Balance/ Duty Cycle) | Fixed
| Pulse Amperage | Fixed (50%)% of Welding Amperage
| AC Frequency | 20-250 Hz
| AC Balance | 20-80% of Positive Electrode
| AC Wave Forms | Square
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 90A/23.6V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 75A/23V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 130A/25.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 100A/24V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 90 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 23,6 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 130 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 25.2 Volts
| Hot Start | Fixed
| Hot Start Time | Fixed
| Arc Force | Fixed
| Anti-Stick Protection | No
| Functions with Remote | No
| Maximum Stick Rod Diameter (Recommended, may vary by mfgr. and type) | 1/8"
Use 6011 for best results
| TIG Function | Built In Gas Valve Standard Torch
| Plasma Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 25A/90V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 20A/88V Rated Output
| Plasma Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 40A/96V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 30A/92V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 20A/88V Rated Output
| Plasma Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Plasma Amp DC Output Range: 20 to 25 Amps
120V 1 Phase 50/60Hz Plasma Volt DC Output Range: 88 to 90 Volts
| Plasma Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Plasma Amp DC Output Range: 20 to 40 Amps
240V 1 Phase 50/60Hz Plasma Volt DC Output Range: 88 to 96 Volts
| Open Circuit Voltage (OCV) | 290V
| Torch Type | S-45
| CNC Capable/Ready | No
| Gouging Capable | No
| Gouging Duties | No Gouging Permitted, Voids warranty
| Drag Cutting | Yes, but only with included standoff
| Parts-In-Place Safety Cut Out | No
| Recommended Flow Rate (Air) | 5.0 CFM
| Compressor Built In | No
| Recommended Cutting Pressure Range | 65-75 PSI
| Remote | 2T
| Tip Saver Function | No
| Location of CNC Port | No CNC Port
| Torch Connector Type | Threaded with 35 DINSE Power Adapter
.007" to 3/16"
.007" to 3/16"
.025"- 3/16"
1/16"- 1/8"
- Up to 3/8" daily use
- Up to 1/2" clean cut
- Up to 5/8" severance cut
- Pierce up to 3/8"
- NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
- S-45 Hand Held Plasma Torch Blow Back Start 15 Ft. Threaded Connector
- NOVA 17 Series Air-Cooled Rigid-Neck TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru)
- 2T/4T Torch Switch for TIG welders 7 pin female 15 Ft.
- 240V to 120V Pig-tail adapter
- 6.5 ft. Power input cable with NEMA 6-50 power plug
- Plasma torch threaded adapter to DINSE
