PowerPro 256Si Cooler and Cart Package
SKU# PP-256SI-375LF-WC375
This package includes everything that the PowerPro 256Si package includes, but also includes the PowerCart 375LF and the PowerCool WC375 water cooler. The PowerPro 256Si has a built in water cooler plug for powering the water cooler so that it works together without running a separate power plug to the cooler.
- 10,500 Surge Watts
- Not for use with E6010 and most cellulosic rods
- E6011 use is permissible but performance may be brand dependent
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 38 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 30 A
| LCD Screen | No
| Memory | No
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 20 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 20 Volts
HF Start with Point Gap Start
| Start Amp Range AC | 20-250A
| Start Amp Range DC | 5-250A
| End Amp Range AC | 20-250A
| End Amp Range DC | 5-250A
| TIG Pulse | AC
| AC Pulse Type | Standard
| DC Pulse Frequency | 5-250 Hz
| AC Pulse Frequency | 5-250 Hz
| AC Frequency | 20-250 Hz
| AC Balance | 10-90% of Positive Electrode
| AC Wave Forms | Square
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 200 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 28.0 Volts
| Hot Start | Fixed
Fixed
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
| Maximum Stick Rod Diameter (Recommended, may vary by mfgr. and type) | 5/32"-3/16"
Use 6011 for best results
| Plasma Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 60A/104V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 50A/100V Rated Output
| Plasma Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Plasma Amp DC Output Range: 20 to 60 Amps
240V 1 Phase 50/60Hz Plasma Volt DC Output Range: 88 to 104 Volts
| Open Circuit Voltage (OCV) | 280V
| Torch Type | iPT-60
| CNC Capable/Ready | No
| Gouging Capable | No
| Gouging Duties | No Gouging Permitted, Voids warranty
| Recommended Flow Rate (Air) | 5.7 CFM
| Compressor Built In | No
| Recommended Cutting Pressure Range | 65-75 PSI
| Remote | 2T
| Tip Saver Function | No
| Location of CNC Port | No CNC Port
| Torch Connector Type | Threaded with 35 DINSE Power Adapter
.007" to 1/2"
.007" to 1/2"
.025"- 5/16"
*Capability varies based on skill, weldment size and general welding knowledge. The maximum limit is a practical recommended single pass limit based on industry standard of performing thicker welds with multiple passes.
1/16"- 5/32" (3/16" some types, depending upon manufacturer)
- Up to 5/8" daily use
- Up to 3/4" clean cut
- Up to 1" severance cut
- Pierce up to 5/8"
- NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
- Rail Car Industry
- Pipe and Structural
- PowerCool W375 (240V)
- TIG Consumable Starter Kit (Tungsten Not Included)
- Plasma Consumable Starter Kit (55-60A)
- 6.5 Ft. Power Input Cable with NEMA 6-50 Adapter
