PowerTIG 400EXT (3Ph 480V), view 1
PowerTIG 400EXT (3Ph 480V), view 2
PowerTIG 400EXT (3Ph 480V), view 3
PowerTIG 400EXT (3Ph 480V), view 4
PowerTIG 400EXT (3Ph 480V), view 5
SKU# PT-400EXT-480
Digital AC/DC
$2,925.00
$2,299.00
Save - $626.00
Digital AC/DC
SKU# PT-400EXT-480
  • Unit Weight: 105 lb
  • Unit Dimensions: 9.25 in × 25 in × 15 in
Built for professional shops that need serious welding power, the PowerTIG 400EXT is the most powerful model in Everlast’s PowerTIG series. It delivers a full 400A of AC/DC TIG output on single-phase power at a 35% duty cycle, providing the capacity to tackle thick plate and heavy weldments. In Stick mode, it produces 315A at a 35% duty cycle and supports electrodes up to 1/4" for demanding fabrication and repair.
Advanced AC Pulse, 4 AC wave forms, and Adjustable AC frequency enhances aluminum welding capability helping you take on a wide variety of Aluminum welding applications. The 400A high output is balanced by low-end TIG capability, giving you control for lighter work.
The familiar digital features, controls and layout of the popular EXT series make upgrading to greater capacity straightforward for shops already using an EXT model. From heavy fabrication to everyday repairs, the PowerTIG 400EXT brings power and versatility to your shop. Just add a power plug, shielding gas and tungsten, and you’re ready to weld.
Key Features
  1. Operates 480V 3 phase for versatile performance options
  2. 5A DC Start and 10A AC Start for excellent arc starts on thinner materials (with small .040" diameter tungsten)
  3. Smooth, stable arc in TIG delivers a higher quality weld
  4. Solid state HV Start removes the issue of point gap maintenance for traditional HF starting
  5. 60% Duty cycle at maximum ouput, regardless of phase the unit is operated on extends operation times for true industrial settings
  6. Advanced AC pulse increases range of AC TIG performance by using a mixed/hybrid AC and DC negative pulse for maximum penetration
  7. 4 Adjustable AC Wave Forms: Advanced Square, Soft Square, Triangular and Sine Wave for improved Aluminum welding control
  8. Fan-on-arc for quieter operation
  2. 15,500Surge Watts on 480V 3 phase
  1. E6010 mode operates best with a short arc
  2. TIG lift start requires a remote to start arc. It is not a live lift function.
480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 19.6 A
480V 3 Phase 50/60Hz: 12 A
21S
9 Programs
On-Arc
Cooler Control
Runs Continuously
TIG Duty Cycle 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 400A/26V Rated Output
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/22.6V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/20V Rated Output
TIG Output Range 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
480V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 26 Volts
480V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
480V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
70V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
10-400A
Start Amp Range DC
5-400A
End Amp Range AC
10-400A
End Amp Range DC
5-400A
0-25 Seconds
0-50 Seconds
0-25 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-250 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
5-100% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
5-90% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Sine
.015" to 1/2"+
.015" to 1/2"+
.025"- 1/2"+
1/16"- 1/4"
  • Aerospace
  • Rail Car Industry
Downloads
