PowerTIG 400EXT & W401 Cooler & Cart 301 & Nova Kit (Bundle)
SKU# PT 400EXT-240V-301-W401-BUNDLE-9
The PowerTIG 400EXT (240V 1 and 3 phase model) bundle package includes the PowerCart 301LF and the PowerCool 401 water cooler. This package gives you everything that normally comes with the PowerTIG 400EXT (240V 1 and 3 phase model) including the standard accessory package. The cooler included in this package stacks securely under the PowerTIG 400EXT with a smooth, connected look. The cart is designed to hold both the welder and cooler If the cooler isn't needed, it can hold just the welder as well. The thumb screws that connect to the bottom of the cooler from under the cart and the top capture bar on the cart keep the welder and cooler from sliding around. This package is perfect for small shops and fabrication facilities that need a compact water-cooled package. Be sure to add a cover after selecting this package under the "add accessories" option to keep the welder protected when not in use.
Includes:
- PowerTIG 400EXT (240V 1 and 3 phase model)
- PowerTIG 400EXT Accessory Package
- PowerCart 301 Welding Cart
- PowerCool 401 Water Cooler
- 19,500 Surge Watts
Package Notes:
- Each item in this package may vary in warranty length. The warranty listed for this package is only for the welder itself.
240V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 79 A
240V 3 Phase 50/60Hz: 39 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 48 A
240V 3 Phase 50/60Hz: 24 A
| LCD Screen | No
| Memory | 9 Programs
| Fan | On-Arc
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 400A/26V Rated Output
| TIG Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 400A/26V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/22.6V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/20V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 26 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
| TIG Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 26 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
| Start Amp Range AC | 10-400A
| Start Amp Range DC | 5-400A
| End Amp Range AC | 10-400A
| End Amp Range DC | 5-320A
| Post-Flow Time | 0-50 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Advanced
| AC Frequency | 20-250 Hz
| AC Wave Forms | Square
Soft Square
Triangular
Sine
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 315A/32.6V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/30V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Duty Cycle 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 315A/32.6V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/30V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 315 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 32.6 Volts
| Stick Output Range 240V 3 Phase 50/60Hz | 240V 3 Phase 50/60Hz Stick Amp DC Output Range: 20 to 315 Amps
240V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 32.6 Volts
| Open Circuit Voltage (OCV) | 70 (<24 with VRD)V
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
| Maximum Stick Rod Diameter (Recommended, may vary by mfgr. and type) | 5/32"-3/16"
| E6010/Cellulose Rod (Electrode) Capable | Yes, but limited to short arc
Use 6011 for best results
| Important Stick Specification Notes | E6010 results may vary with rod manufacturer. Keep a short arc or drag rod for best performance.
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
1/16"- 5/32" (3/16" some rods)
- Aerospace
- Rail Car Industry
- NOVA 20 Series Water-Cooled Rigid-Neck TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru)
- PowerCool W401 (240V)
- PowerCart 301 HD Welding Cart with Single Cylinder Capacity
- 6.5 Ft. Power Input Cable (Power plug not included)
- TIG Starter Consumable Kit
