Typhoon 500, view 1
Typhoon 500, view 2
Typhoon 500, view 3
Typhoon 500, view 1
Typhoon 500, view 2
Typhoon 500, view 3
SKU# TYP-500
Typhoon 500
Digital AC/DC
$6,449.00
Typhoon 500
Digital AC/DC
SKU# TYP-500
  • Unit Weight: 62 lb
  • Unit Dimensions: 9.5 in × 26 in × 15 in
Typhoon 500
  1. 240V 1 and 480V 3 phase input
  2. AC/DC Pulse TIG with AC/DC Stick Output sets the standard for features and adjustability
  3. 400A output @ 60% Duty Cycle while operating on 240V 1 phase
  4. 500A output @ 60% Duty Cycle while operating on 480V 3 phase
  5. 7" 720 HD TFT screen allows easy viewing of parameters with high contrast graphics that can be viewed at a distance
  6. See and adjust all parameters on main screen without the bottle neck created by hidden pop-up menus
  7. Independent Amplitude Control on AC allow the Tungsten to last longer and improves penetration
  8. Single and Double Pulse DC TIG for maximum heat control and steady arc
  9. Standard AC and Advanced AC TIG (Mixed) Pulse
  10. Industry leading 5 AC wave forms with ability to assign individual half-wave forms with a total of 15 possible combinations, not including the unique wave form possible when using the AC Advanced Pulse
  11. Fully adjustable low Amp HV starting with ability to select tungsten size for maximum precision starts
  12. Remote control with Stick for maximum control with pedal or slider
  13. Dedicated cooler outlet installed in rear for use with water-cooled torch
  14. Fan-on-Arc or Temp Control for quieter operation or select full time operation for heavy duty use
  15. Cooler-on-Arc or full time cooler control when used with optional cooler
  2. 16,500 Surge Watts (240V 1 phase)
  3. 20,000 Surge Watts (480V 3 phase)
  1. Unit is equipped with separate water cooler and wire less foot pedal power outlets.
  2. Do not plug any other device into the water cooler outlet or into the outlet intended for powering the wireless foot pedal.
480V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 63 A
480V 3 Phase 50/60Hz: 24 A
240V 1 Phase 50/60Hz: 50 A
480V 3 Phase 50/60Hz: 19 A
7 inches
Type
TFT
Resolution
720
21S
30 Programs
Temperature Controlled
On-Arc
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 400A/26V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 315A/22.6V Rated Output
TIG Duty Cycle 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 500A/30V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 390A/25.6V Rated Output
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 26 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
TIG Output Range 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz TIG Amp AC Output Range: 10 to 500 Amps
480V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 30 Volts
480V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 500 Amps
480V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 30 Volts
95V
TIG Start Type
Live Lift Start
Lift Start With Remote
Start Amp Range AC
5-(400)500A
Start Amp Range DC
10-(400)500A
End Amp Range AC
10-(400)500A
End Amp Range DC
10-(400)500A
0-30 Seconds
0-60 Seconds
0-30 Seconds
0-60 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
Triangular
Trapezoid
Sine
Double
DC Pulse Frequency
0-0-999 Hz
DC Double Pulse Frequency
0-9.9 Hz
AC Pulse Frequency
0-500 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
3-100% of Welding Amperage
AC Frequency
20-400 Hz
AC Balance
5-70% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Trapezoid
Sine
Other Functions
Fast Tack (Cold Weld Function) Spot and Stitch Timer
.015" to 1/2+"
.015" to 1/2+"
.025"- 1/2+"
1/16"- 1/4+"
  • Aerospace
  • Rail Car Industry
  • Pipe and Structural
  • Gunsmithing
Downloads
