Cyclone 312i & Parker SGP 360 Push Pull Gun & Cart 375LF (Bundle)
SKU# CLN-312i-SGP360-375LF-BUNDLE-PP
- Shipping Weight: 79 lb
The Everlast Cyclone 312i push-pull and cart package is bundled with the Cyclone 312i, the Parker SGP 360 Push-Pull Gun, and the NOVA PowerCart 375LF welding cart. This package includes all the accessories included in the Standard Everlast Cyclone 312i package, including the standard accessories. This is package is best for heavy duty MIG welding of aluminum or stainless wires at a long distance away from the welder. Larger spools of wire are more economical and last a longer time between changes over the 1 lb spools of aluminum wire used on spool guns. Typically push-pull guns offer improved welding results.
Includes:
- Cyclone 312i
- Cyclone 312i accessory package
- NOVA PowerCart 375LF
- Parker SGP 360 Push-Pull Gun 25 Ft.
- 16,500 Surge Watts
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 64 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/29.8V Rated Output
| Up-Slope Time | 0-1 Seconds
2T SP
4T SP
| MIG Pulse | None
| Spool Sizes | 8”
12”
Steel V-groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
| Other MIG Functions | Spot
Stitch
| Wire Feed Speed | 600IPM
| Torch/Gun | 36 Series 10 Ft. (North)
| Important MIG Specification Notes | Purchase a separate liner for each wire size that will be used. For under 230A operation, purchase a 24 series gun.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 250A/30V Rated Output
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/22.6V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 22.6 Volts
24 gauge to 1/2"
22 gauge to 1/2"
1/8-7/16"
1/16"- 3/16"
.015" to 1/2"
.015" to 1/2"
- Aerospace
- Parker SGP 360A Air-Cooled Push-Pull Gun (7 Pin) 25 Ft. Euro Quick Connect
- Parker SGP360 Push Pull Gun (promo)
