Lightning 225 MTS & Parker DSP 240 Spool Gun, view 1
Lightning 225 MTS & Parker DSP 240 Spool Gun, view 2
Lightning 225 MTS & Parker DSP 240 Spool Gun, view 3
Lightning 225 MTS & Parker DSP 240 Spool Gun, view 4
Lightning 225 MTS & Parker DSP 240 Spool Gun, view 5
Lightning 225 MTS & Parker DSP 240 Spool Gun, view 6
Lightning 225 MTS & Parker DSP 240 Spool Gun, view 7
Lightning 225 MTS & Parker DSP 240 Spool Gun, view 8
SKU# LMTS-225-DSP240
MIG
$2,898.00
$2,378.00
Save - $520.00
MIG
  • Unit Weight: 87 lb
  • Unit Dimensions: 11.5 in × 26 in × 17.5 in
The Lightning 225 MTS with the Parker DSP 240 spool gun package bundles both the Lightning 225 and the Parker DSP 240 together for a complete welding package. This package also includes all the regular accessories of the Lightning 225 MTS package plus the spool gun. This gun adds a dimension to your welder, allowing you to weld aluminum and extend your welding distance up to 25 ft.
Includes:
  1. Lightning 225 MTS
  2. Lightning 225 MTS Accessory package
  3. Parker DSP 240 Spool Gun
  2. 7,500 Surge Watts
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 28 A
240V 1 Phase 50/60Hz: 31 A
120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 19 A
5.1 inches
Type
TFT
Resolution
720
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 225A/25.3V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 170A/22.5V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
70V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-5 Seconds
0-20 Seconds
0-1 Seconds
0-1 Seconds
MIG Pulse
None
Spool Sizes
4”
8”
.035”
V-Groove
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Run-In
Spot
Stitch
Wire Feed Speed
120V: 400 IPM 240V: 600 IPM
Torch/Gun
North 24 Series 10 Ft.
24 gauge to 5/16"
20 gauge to 5/16"
1/8"- 5/16""
.015" to 3/8"
.015" to 5/16"
.025"- 1/4"
1/16"- 5/32"
