Lightning 225 MTS, view 1
Lightning 225 MTS, view 2
Lightning 225 MTS, view 3
Lightning 225 MTS, view 4
Lightning 225 MTS, view 5
Lightning 225 MTS, view 6
SKU# LMTS-225
Lightning 225 MTS
MIG
$2,499.00
$1,999.00
Save - $500.00
Lightning 225 MTS
MIG
SKU# LMTS-225
  • Unit Weight: 87 lb
  • Unit Dimensions: 11.5 in × 26 in × 17.5 in
Lightning 225 MTS
The Lightning MTS 225 combines professional welding power with simple, intuitive controls. From everyday fabrication to thicker material requiring multiple passes, it offers the power, control, and flexibility to tackle a wide range of work. Delivering up to 225A in MIG and AC/DC TIG and 185A in Stick, it handles easily common welding chores that are associated with fabrication, maintenance, and portable welding. Dual-voltage 120/240 power input capability provides ultimate job-site flexibility and go-anywhere performance.
The PowerSET mode speeds setup by recommending basic starting-point settings based on user defined parameters in MIG, TIG, and Stick modes. After defining welding parameters like wire diameter/electrode size and type, add in the material thickness, all you need to do is fine-tune voltage and wire feed speed in MIG or fine tune amperage in TIG and Stick to match the job.
A dedicated self-shielded Flux-Core mode expands versatility, while separate mixed-gas and 100% CO₂ MIG modes optimize steel welding performance. For aluminum MIG welding, the unit supports compatible push-pull guns and the heavy-duty Parker DSP 360 spool gun.
  1. Dual Voltage Operation allows maximum go-anywhere performance
  2. MIG,TIG and Stick operation handles almost any common welding chore
  3. Spool Gun Capable (spool gun optional)
  4. Run-in features improves arc starting in MIG mode
  5. Push Pull Gun Capable (Push-Pull gun optional)
  6. 5.1" LCD HD 720 Screen for easy view of parameters
  7. 4 Roller drive system for smooth feeding of wire on longer guns and push-pull guns
  8. 8" or 4" roll capacity (2 lb. or 10-12lb.) provide economical choices of wire selection.
  2. 7,500 Surge Watts
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 28 A
240V 1 Phase 50/60Hz: 31 A
120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 19 A
5.1 inches
Type
TFT
Resolution
720
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 225A/25.3V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 170A/22.5V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
70V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-5 Seconds
0-20 Seconds
0-1 Seconds
0-1 Seconds
MIG Pulse
None
Spool Sizes
4”
8”
.035”
V-Groove
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
MIG Functions
Wire Jog
Run-In
Spot
Stitch
Wire Feed Speed
120V: 400 IPM 240V: 600 IPM
Torch/Gun
North 24 Series 10 Ft.
24 gauge to 5/16"
20 gauge to 5/16"
1/8"- 5/16""
.015" to 3/8"
.015" to 5/16"
.025"- 1/4"
1/16"- 5/32"
Downloads
