Lightning 225 MTS with Parker DSP 240 Package
SKU# LMTS-225-DSP240
- Unit Weight: 87 lb
- Unit Dimensions: 11.5 in × 26 in × 17.5 in
The Lightning 225 MTS with the Parker DSP 240 spool gun package bundles both the Lightning 225 and the Parker DSP 240 together for a complete welding package. This package also includes all the regular accessories of the Lightning 225 MTS package plus the spool gun. This gun adds a dimension to your welder, allowing you to weld aluminum and extend your welding distance up to 25 ft.
Includes:
- Lightning 225 MTS
- Lightning 225 MTS Accessory package
- Parker DSP 240 Spool Gun
- 7,500 Surge Watts
- Use for hand cutting plasma only. CNC use voids warranty.
240V 1 Phase 50/60Hz: 31 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 19 A
| LCD Screen | No
5.1 inches
| Type | TFT
| Resolution | 720
| Memory | 30 Programs
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 125A/20.3V Rated Output
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 225A/25.3V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 170A/22.5V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
| MIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
| Pre-Flow Time | 0-5 Seconds
| Post-Flow Time | 0-20 Seconds
| Up-Slope Time | 0-1 Seconds
| MIG Pulse | None
| Spool Sizes | 4”
8”
V-Groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
Spot
Stitch
| Wire Feed Speed | 120V: 400 IPM 240V: 600 IPM
| Torch/Gun | North 24 Series 10 Ft.
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/14.8V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 225A/19V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/18V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 15 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 15 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 225 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 19 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 225 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 19 Volts
| Start Amp Range AC | 20-(125)225A
| Start Amp Range DC | 10-(125)225A
| End Amp Range AC | 20-(125)225A
| End Amp Range DC | 10-(125)225A
| Up-Slope Time | 0-5 Seconds
| Down-Slope Time | 0-5 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Soft Square
Triangular
| Pulse Amperage | 3-95% of Welding Amperage
| AC Frequency | 20-200 Hz
| AC Wave Forms | Square
Soft Square
Triangular
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 100A/24V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/23.2V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 185A/27.4V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/26.4V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 185 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 27.4 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
| E6010/Cellulose Rod (Electrode) Capable | Yes, but limited to short arc
Use 6011 for best results
24 gauge to 5/16"
20 gauge to 5/16"
1/8"- 5/16""
.015" to 3/8"
.015" to 5/16"
.025"- 1/4"
1/16"- 5/32"
- 24 Series MIG Gun 3m 10 ft.
- Parker DSP 240A Spool Gun (7 Pin) 25 Ft. Euro Quick Connect
- 240V to 120V Pigtail Adapter
- Starter Consumable TIG Kit
- 6.5 Ft. Power Cable and NEMA 6-50 Power Plug
