Lightning 225 MTS Spool Gun and Parker DSP 240 with 375LF Cart Bundle, view 1
Lightning 225 MTS Spool Gun and Parker DSP 240 with 375LF Cart Bundle, view 2
Lightning 225 MTS Spool Gun and Parker DSP 240 with 375LF Cart Bundle, view 3
Lightning 225 MTS Spool Gun and Parker DSP 240 with 375LF Cart Bundle, view 4
Lightning 225 MTS Spool Gun and Parker DSP 240 with 375LF Cart Bundle, view 5
Lightning 225 MTS Spool Gun and Parker DSP 240 with 375LF Cart Bundle, view 6
Lightning 225 MTS Spool Gun and Parker DSP 240 with 375LF Cart Bundle, view 7
Lightning 225 MTS Spool Gun and Parker DSP 240 with 375LF Cart Bundle, view 8
Lightning 225 MTS Spool Gun and Parker DSP 240 with 375LF Cart Bundle, view 9
SKU# LMTS-225-DSP240-PC375LF
MIG
$3,127.00
$2,587.00
Save - $540.00
MIG
  • Unit Weight: 87 lb
  • Unit Dimensions: 11.5 in × 26 in × 17.5 in
This is the complete professional package setup. With the Lightning 225 MTS, the Parker DSP 240A and the NOVA PowerCart 375LF, the unit is ready to tackle day to day jobs around the shop.
What's Included:
  1. Lightning 225 MTS
  2. Lightning 225 MTS accessory package
  3. Parker DSP 240A spool-gun 25 ft.
  4. NOVA PowerCart 375LF welding cart
  2. 7,500 Surge Watts
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 28 A
240V 1 Phase 50/60Hz: 31 A
120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 19 A
5.1 inches
Type
TFT
Resolution
720
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 225A/25.3V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 170A/22.5V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
70V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-5 Seconds
0-20 Seconds
0-1 Seconds
0-1 Seconds
MIG Pulse
None
Spool Sizes
4”
8”
.035”
V-Groove
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Run-In
Spot
Stitch
Wire Feed Speed
120V: 400 IPM 240V: 600 IPM
Torch/Gun
North 24 Series 10 Ft.
24 gauge to 5/16"
20 gauge to 5/16"
1/8"- 5/16""
.015" to 3/8"
.015" to 5/16"
.025"- 1/4"
1/16"- 5/32"
