PowerPlasma 62i & PTM-60 CNC Torch (Bundle), view 1
PowerPlasma 62i & PTM-60 CNC Torch (Bundle), view 2
PowerPlasma 62i & PTM-60 CNC Torch (Bundle), view 3
PowerPlasma 62i & PTM-60 CNC Torch (Bundle), view 4
PowerPlasma 62i & PTM-60 CNC Torch (Bundle), view 5
PowerPlasma 62i & PTM-60 CNC Torch (Bundle), view 6
SKU# SKU# PP-62I-CNC-BUNDLE
Hand or CNC Cutting
$1,525.00
$1,425.00
Save - $100.00
Hand or CNC Cutting
  • Shipping Weight: 53 lb
  • Unit Dimensions: 9.75 in × 25 in × 17 in
The PowerPlasma 62i is designed to cater to the needs of small and medium sized repair and fabrication shops routinely hand cutting steel up to 1/2" to 3/4" plate steel with occasional cuts up to 1" or slightly over. This unit's torch offers a wide variety of sizes of consumables from 20A (.6mm/ .023") up to 60A (1.2mm/ .040") diameter orifice cutting tips that allow for a relatively narrow kerf width when properly matched to the cut thickness of the metal. The unit is no lightweight contender. This unit can sustain a 60% duty cycle at full output and operates comfortably on standard 50A 240V circuits.
  1. CNC Port Built-in
  2. IPT-60 Hand Torch
  3. Blow-Back Style Pilot Arc Torch
  4. Parts in Place safety
  5. Low air pressure cut out
  7. Gouge (light gouging) function
Generator Requirements*:
  2. 10500 Surge Watts
*Not following these requirements will void the plasma cutters's warranty.
Important Note:
240V 1 Phase 50/60Hz: 38 A
240V 1 Phase 50/60Hz: 30 A
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 60A/104V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 50A/100V Rated Output
300V
Arc Start Type
Blowback, Piston Type
Torch Type
iPT 60 Hand Torch
CNC Capable/Ready
Yes, with optional Torch
Gouging Capable
Gouging Duties
Light
Drag Cutting
Post Flow Timer
Adjustable
Parts-In-Place Safety Cut Out
Recommended Flow Rate (Air)
5.3 CFH @ 90 PSI
Maximum Supply Pressure
90 PSI
Compressor Built In
30 Gallon
65-75
Remote
Tip Saver Function
Location of CNC Port
Rear
CNC Port Type
WEiPu SP21 12 pin
Torch Connector Type
Central Euro
  1. Up to 3/4" daily use
  2. Up to 1" clean cut
  3. Up to 1 1/4" severance cut
  4. Pierce up to 1/2"
Units are supplied with a starter set of consumables intended primarily for cutting in the 55-60 amp range. While there is effectively no practical minimum material thickness that can be cut, standard higher-amperage tips may produce an unnecessarily wide kerf on very thin material. For best results on lighter gauges, use a consumable with a smaller orifice matched to the required cutting amperage.
  1. Up to 3/8 daily use
  2. Up to 3/4" clean cut (edge start)
  3. Pierce up to 3/8"
  • Aerospace
  • Pipe and Structural
Downloads
