SKU# PP-62I-CNC
- Shipping Weight: 52 lb
- Unit Dimensions: 9.75 in × 25 in × 17 in
The PowerPlasma 62i is recommended for small and medium sized fabrication and repair shops wanting to cut up to 3/8" steel plate on a daily basis. Though that is not the cutting limits of the plasma cutter, with the ability to cut well over 3/4", this is the size that many shops tend to use for CNC cutting on smaller tables and matches best with productive cut speeds typically desired for production or high volume cutting.
- CNC Port Built-in
- Blow-Back Style Pilot Arc Torch, PT60M (Machine torch)
- Parts in Place safety
- Low air pressure cut out
Generator Requirements*:
- 10,500 Surge Watts
Important Note:
Hand torch not provided for hand cutting or gouging. However, it is optional. Once this product is added to the cart, select the add accessories option to select and purchase the length torch at a discounted rate.
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 38 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 30 A
| LCD Screen | No
| Memory | No
| Plasma Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 60A/104V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 50A/100V Rated Output
| Open Circuit Voltage (OCV) | 300V
| Torch Type | iPT 60 Hand Torch
| CNC Capable/Ready | Yes, with optional Torch
| Gouging Duties | Light
| Recommended Flow Rate (Air) | 5.3 CFH @ 90 PSI
| Compressor Built In | No
| Remote | 2T
| Tip Saver Function | Yes
| Location of CNC Port | Rear
- Up to 3/4" daily use
- Up to 1" clean cut
- Up to 1 1/4" severance cut
- Pierce up to 1/2"
Units are supplied with a starter set of consumables intended primarily for cutting in the 55–60 amp range. While there is effectively no practical minimum material thickness that can be cut, standard higher-amperage tips may produce an unnecessarily wide kerf on very thin material. For best results on lighter gauges, use a consumable with a smaller orifice matched to the required cutting amperage.
- Up to 3/8 daily use
- Up to 3/4" clean cut (edge start)
- Pierce up to 3/8"
- Aerospace
- Pipe and Structural
- iPT-60 Hand Plasma Torch Blow Back Start 14 Ft. Central Connector
- WEiPu SP21 CNC Connector 12 Pin
- Starter Consumable Kit (5) IPT-60 Electrodes, (5) IPT 60 1.2 mm (60A) Cutting Tips
