PowerPlasma 82i & PTM-80 CNC Torch Bundle
SKU# PP-82I-CNC-BUNDLE
- Unit Weight: 53 lb
- Shipping Weight: 62 lb
- Unit Dimensions: 9.75 in × 25 in × 15 in
The PowerPlasma 82i is a professional plasma cutter ideal for any shop that needs serious cutting power with 240V 1 phase power. This unit features a heavy duty 80 amp hand cutting torch which works perfectly to cut up to and over 1" steel on a regular basis.
This bundle package includes both torches: IPT-80 Handheld Torch and PTM-80 CNC/Machine Torch.
- 240V 1 phase input power
- CNC Port Built in
- Blow-Back Style, Pilot Arc Hand Cutting Torch
- Parts in Place safety cut out
- Low air pressure safety cut out
- Gouge function
Generator Requirements*:
- 14.000 Surge Watts
Important Note:
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 55 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 43 A
| LCD Screen | No
| Memory | No
| Plasma Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/112V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 60A/104V Rated Output
| Open Circuit Voltage (OCV) | 300V
| Torch Type | iPT 80 Hand Torch
| CNC Capable/Ready | Yes, with optional Torch
| Gouging Duties | Medium
Heavy
| Recommended Flow Rate (Air) | 6.5 CFH @ 90 PSI
| Compressor Built In | No
| Recommended Minimum Compressor Size | 60 Gallon
| Remote | 2T
| Tip Saver Function | Yes
| Location of CNC Port | Rear
- Up to 1" daily use
- Up to 1 1/4" clean cut
- Up to 1 7/16" severance cut
- Pierce up to 5/8"
Units are supplied with a starter set of consumables intended primarily for cutting in the 70-80 amp range. While there is effectively no practical minimum material thickness that can be cut, standard higher-amperage tips may produce an unnecessarily wide kerf on very thin material. For best results on lighter gauges, use a consumable with a smaller orifice matched to the required cutting amperage.
- Up to 5/8" daily use
- Up to 1" clean cut (edge start)
- Pierce up to 1/2"
- Aerospace
- Pipe and Structural
- IPT-80 Hand Plasma Torch Blow Back Start 14 Ft. Central Connector
- WEiPu SP21 CNC Connector 12 Pin
- Starter consumable kit: 5 electrodes, 5 (1.2mm/.047") cutting tips
- 6.5 Ft. Power input cable and NEMA 6-50 Plug
